Speaker Stands Suggestions
I have a new pair of Monitor 40's...
Which stands, Wood or Metal and which height? Was wondering if one or the other had any undesirable qualities effecting sound?
Thanks,
Randy
Thanks,
Randy
Post edited by RandyBox on
F1nut found a web site that has some good stands. I thought I bookmarked it but I did not.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
one used to be able to get great speaker stands (metal / fillable) here on the Polk website, but i have not seen them since.
I forget what they were called, but the were Sanus Brand and I think call "Ultimates"
Or something like that ?
There are many good choices out there .... some of my favorites are the ones they use with the older Sonus Fabers...Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
what kinda speakers do you have and are you using them for tv? a ht pj ? . i have rti6 and fxi3's all in black and i must say that the wood technology solid hardwood ebony finish is like practicaly an extention of the rti cabinets, for ht you wana go with 21 inch fronts 19 inch centre and 40 inch to elevate the rears, idealy you should have the rears 3 foot above the ear and the front sound stage slightly below me thinks
i got carried away and never noticed the m40, lol , same applies if them m40's are black ' go with the wood tech, you can get free shipping(even on the return) from racksandstands.com
Thanks, found them on Ebay 17.5" for 29.99, but the 24.5" are only $5 more...My Montor 40's are black so they should work out nicely...
Thanks,
Randy -
I just browsed racksandstands. I'm really glad you put that up. I'm new on this site and I learn something almost daily thanks to all you guys.
potee -
These are excellent (the best, IMO) speaker stands and they will also custom make them to your specs.
http://www.skylanstands.com/stands.htm
Highly recommended!!!Political Correctness'.........defined
President of Club Polk -
Thanks,
Randy
Go to the lumber yard, buy some wood. Make your own.Panny 8000 project
Oppo 103D
Fronts- Monitor 70's
Upper fronts- Monitor 30's
Surrounds- Monitor 50's
Backs- Monitor 40's
Center-CS 350
Sub- SVS PB 2000
Onkyo 607[back up] -
I have some new Plateau F-23 metal stands I will sell. Brand new. Never used them. 23". Perfect height for Monitor 40's.
Nice! Too bad I'm on a chicken & rice diet for the next 3 weeks in order to pay for those Monitor 70's...:rolleyes:
Randy -
if randys buyin m40's why would you post these guys website ? it just doesnt make any sense at all. All them stands are like 4 and 5 times the price of his speakers and would quite frankly look ridiculas mounted on them . Ive heard many a polkie say that your stands should not cost more than the speakers -
He asked for suggestions and I offered one. Why should that matter to you?All them stands are like 4 and 5 times the price of his speakers and would quite frankly look ridiculas mounted on them .
They are priced in CN dollars, so the single post 26" stand is actually $176.00 US. Why would they look ridiculous? Skylan will make the stands and plates any size you want.Ive heard many a polkie say that your stands should not cost more than the speakers
You've been here less than a month. Just how many Polkies have said that to you? Besides, there's absolutely no reason a pair of stands can't cost more than the actual speakers.Political Correctness'.........defined
just because i signed up a month ago means nought, you can access this site freely as a guest , My point is that its similar to buying a set of 2000 dollar rims for a car that cost 500
The OP asked for suggestions. Thuffman03 actually brought it up first that I had suggested stands in the past, but didn't have the link. I supplied the info. You don't have to buy a damn thing that I suggest, so again, why does it matter to you? That's a rhetorical question.
BTW, your analogy is ridiculous.Political Correctness'.........defined
