Bel Canto Dac3 to replace Benchmark Dac1
BlueFox
Does anyone have any experience with the Bel Canto Dac3, especially if you have compared it to the Benchmark Dac1? I have an upgrade itch, and this seems like a nice step up from the Benchmark Dac1. But, if there really is not a significant improvement then perhaps it isn't a worthwhile upgrade, at least at this time.
Thanks.
Thanks.
Post edited by BlueFox on
Stereophile did a comparison about a year ago or so, I cannot find the link. First I ask, what exactly is the Benchmark not doing that you feel the BC Dac3 will?
Venom -
Venom
Thanks. I found a 2007 review. Reading between the lines, it seems to me they are saying it is, essentially, the same as the Dac1. They feel the Dac1 is better in the lows, and the Dac3 is a bit clearer in the highs.
"I so wish that Bel Canto's e.One DAC3 had been priced closer to $1250 than to $2500. The former would make it a no-brainer credit-card purchase for almost any audiophile wanting digital playback quality that is the state of the art ca 2007. At $2495, its purchase should be a more considered decision. "
http://stereophile.com/digitalprocessors/1107bc/
The Dac1 is great, but like everything else in this hobby, there is always something better. Maybe I will have to look harder at the Berkely Audio Design Alpha Dac.
http://www.berkeleyaudiodesign.com/products.htmlLumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I have only had the Benchmark a little while now, before that I had a Bel Canto Dac 1.1 and a number of cd players over the years. My take on this is that when I hear a review of some dac or pre saying how warm it was, it can sometimes mean that colorization is added. I feel that I would want every ounce of information sqeezed from the source with the utmost jitter control; enter the Benchmark. One can always tweek the sound further down the chain with cables, pre's amps....but once the signal is tweeked at the source, everything else in the chain has less to work with. My 2 cents.
steveinaz and I compared the Benchmark and the Bel Canto DAC2 at his house a few years ago. Besides appearance and a bit more functionality from the Benchmark, we were hard pressed to find any notable differences. The only thing we noticed was that on a passage with some noticeable hand clapping keeping the rhythm, the Bel Canto was ever so slightly more natural sounding.
I have since upgraded from the DAC2 and have found the Cambridge Audio azur 840c CDP to be superior in every way: cleaner, more detailed but not bright, better image and width, naturalness, etc. If I were upgrading from the Benchmark (or one a few years old) I'd look hard at the Cambridge.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
As well as a great digital section,the discrete Class A analog stage makes this one a serious contender.http://bryston.com/bda1_m.htmltheres always something better.Testing
Testing
Testing -
Thanks!!
It is only $500 more than the Dac1, is $500 less than the Bel Canto Dac3, and $3000 less than the Berekley Alpha Dac. If it works as good as their marketing spec sheet says then it should be a good upgrade from the Benchmark Dac1.Lumin X1 file player, Westminster Labs interconnect cable
Wes
That is interesting. stereophile recently reviewed the $400 Cambridge-Audio DacMagic and said it was equal to the $1500 Cambridge-Audio 840C in regard to sound quality.Lumin X1 file player, Westminster Labs interconnect cable
I have heard it and it's the real deal.I believe its analog stage sets it apart from the competition.If you like detailed (but not overly analytical) mids and treble,great dynamic slam and deep bass then it may be to your liking.Thanks!!
It is only $500 more than the Dac1, is $500 less than the Bel Canto Dac3, and $3000 less than the Berekley Alpha Dac. If it works as good as their marketing spec sheet says then it should be a good upgrade from the Benchmark Dac1.Testing
Testing
Testing -
Agreed, The Benchmark ran straight from the amp is incredible.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
The DAC 3 is simply amazing. One thing to separate the Bel Canto vs the Benchmark is feed it using the Bel Canto CD 2 outputing 24bit signal. The dimension of the soundfield and separation of instruments are the best I ever heard. Except from the Esoteric showroom at CES, but that adds another digit your equipment costs.
Oh, two things, the build quality on the Bel Canto just feels that much more solidifying.
