HCT 100 tuber
lightman1
Looking at modding the HCT Fat Man I-pod thingy amp to a tube pre buffer.
i.e. bypassing the amplifiers and running low level straight out to a power amp.
I'm pretty handy with a soldering iron, so lay it on me.
Russ
Russ
Post edited by lightman1 on
Come over. It's easy.
Later ****.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Enlighten me, O wise sauce-head guru of the tractor wheelies!Come over. It's easy.
Later ****. -
Here:
http://gainphile.blogspot.com/2007/11/dared-mp-5-impression-and-modification.html
and here:
http://www.datasheetcatalog.org/datasheet/stmicroelectronics/1478.pdf
Let us know how it turns out. I have (2) of these and I want to make one into a pre.
It is an easy mod and I like to use Canare L-4E6S to run my signals in electronics. The double-twisted design is nice, but using any signal wire that is shielded, especially past transformers and such, really help keep the noise down.
I'm on it! Thanks H9.Here:
and here:
I'll get it done this weekend and give it a spin.
Russ -
Noted. Thanks Zingerdinger -
Well I must say I'm fairly impressed with the little bypass surgery I did on the 100. Nothing blew up and it still works. All in all not a bad presentation of sound from the little feller. Our illustrious tube freak of the week, George Daniel, steered me in the right direction to upgrading the tubes in it. Gonna try out the Amperex 7119 tubes and see if they can bring out any more details.
A Question. Will this help with the output gain to the amp? I have to turn it up to almost 3/4 on the knob to really start getting some nice volume from it. The Cats-Eye tube in the back is maxed.
Tried it out with a Denon POA-1500 and a Carver m-200t amp running a set of 2Bs. (thanks Eric)
The Denon had whompus low-end and mids and rolled smoothly in to the highs. Detailed but not so much that it was sterile.
The Carver was too....forward...bright...
Just thinking a little more low level output from the HCT might tame some of this.
My thoughts...and welcome y'alls.
Thanks,
Russ -
Pics or it didn't happen.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
It happened, fo sho! Just don't have a camera around here. Pics later, putz.Pics or it didn't happen. -
Thanks,
Russ
I certainly respect Georges opinion but be careful what tubes you use. I;ve done some research and European ECC85's work, 6AQ8's work and Russian 6N1p's work. The 6N1P's have the highest gain with the Chinese tube being 2nd and the ECC85 being a close third.
I have Siemens Falcon logo (ECC85), Blackburn RCA's (same as Mullards)(6AQ8) German RFT's (ECC85) and several early 70's Russian military tubes(6N1P-EV)
For vocals and tone the RCA's and Siemens sound great w/a great holographic soundstage. All around rock and jazz, the RFT's sound good and the Russian tubes are excellent for thicker bass and rock oriented music. The Russian tube is a great tube it just lacks the depth and sound stage of the European tubes.
A friend has 60's era Telefunken (ECC85) in his and loves them.
Thanks H. Taking notes and getting my feet wet in this tube thing y'all keep talking about.
Do you have a pair of the ECC85's available for sale? Trade? Try?
Thanks again, H
Russ -
Congrats on the successful mod. Anything else planned for that little amp, or are you just going to roll tubes for a while?
Just gonna try some tubes for now. Maybe get into the guts later. Have to study the layout on the board.
