Klipsch Sub-12 vs. older Velodyne HGS-12...opinions needed.
Ethancf
Ethancf Posts: 478
So I have a Klipsch Sub-12 that I've been running for the last couple of years in my HT. Sounds great. I was looking at an older Velodyne HGS-12 on Craigslist (local) for $750. The guy had a circuit board replaced on it and claims that it's in perfect shape...no scratches or flaws to speak of. I'm not sure if it's a Series II. Anyway, this sub sounds pretty high end, but it's years old.
1. Would you say the price is fair?
2. Would an older sub like that sound better than what I currently have?
I'd really like your opinions on this one. -Thanks!
THE SYSTEM
Polk Audio LSiM 707 Mains
Polk LSiM 702 f/x Surrounds
Polk Audio LSiM 706 C Center
SVS SB-17 Ultra Subwoofer
Rotel RSP-1582 Pre/Pro
Rotel RMB 1585 Amplifier
Oppo UDP-205 Blu-ray Player
Samsung PN64D550 64" Plasma
Post edited by Ethancf on
  • Ron Temple
    Ron Temple Posts: 3,212
    edited June 2009
    Overall output will be similar, but the Velo will be much tighter, more linear and sound much better. That said, it is getting up there and likely to have some problems down the road. $750 is a reasonable price from the sellers perspective. I don't think I'd got that high. For $750, I'd probably put my money toward an Epik Vanquish and get the full warranty.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Dawgfish
    Dawgfish Posts: 2,554
    edited June 2009
    +1 on what Ron Temple said. You can buy a really nice new sub for $750.
    I am not familiar with the Velodyne sub in question, but I do know Velodyne makes a good product. Still though, $750 is a lot to pay for a used sub.
    I also own a Klipsch Sub-12. Personally I feel this is good home theater sub, but it is severely lacking for music. I have two DSW Pro 600s in my main system, and compared to the Sub-12, the DSWs are much tighter, more detailed, and accurate. They don't dig quite as low as the Klipsch for home theater, but they are close. To me they are a much better all around sub than the Sub-12. I would strongly look at those (or any of the other DSW Pro or Micro Pro subs) and look at some of the other good quality subs out there from Hsu, SVS, Epik, Paradigm, Velodyne, etc. You have a lot of quality options for $750.
  • danz1906
    danz1906 Posts: 5,144
    edited June 2009
    Ron Temple wrote: »
    Agreed, Look at some new subs from SVS and EPIK.
    Also check this used sub out:
    http://www.audiogon.com/cgi-bin/cls.pl?homesubw&1249408286&/Epik-Valor-Subwoofer
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • Ron Temple
    edited June 2009
    Don't get me wrong the HGS is a heck of a sub. It was replaced by the DD series and there's not much difference in SQ. It's probably at least 6-7 years old though and when something goes (usually the amp), replacement and/or repair, can be time consuming and costly.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
