GNX124 vs Polk/MOMO MM2124
Systems
I have a pair of 12" Polk Audio GNX124 Subs. I just saw online that Polk/MOMO came out with a new sub called Polk/MOMO2124. On Crutchfield.com, the MOMO's are 140$ per sub. And the GNX are 160$ per sub. How come the GNX costs more, even though the MOMO's are newer? I was just wondering If I should keep the GNX's or get the new MOMO's. And can someone plz tell me which one is better?
Thanks!
Thanks!
Testing
Testing
Testing
Testing
Testing
dude use your GNX's as a port-a-potty and go snag some of the new momo subs...
i haven't heard them yet but i'm going to at some point soon... specs look to be a slight improvement over the DX series.
sensitivity is up 2 db's / power handling is the same at 400 watts rms / magnet weight it up by 50% from 40 oz. to 60 oz.
if it sounds as good as its specs... then i've got a new favorite polk sub.
the gnx however, i loathe with a hatred suited only for the most base creatures.
head to head the new momo beats the gnx by over 200 watts RMS power handling / excursion has to be much less / rigidity of the cone i would image is much less on the GNX / and overall build quality probably is too.
go hit up circuit city -- and try one out... then you'll know for yourself.. buy it form crutchfield or wherever your'e happy but for now just find a store that has one in stock that u can listen to.
150 bucks for that sub is not bad money either -- to me, if it is as good as i hope, its worth 200 ... i dont wanna have to pay 200 for it...lol... ebay... but its worth it. that's what IDQ's go for.
i do so hope this new momo sub also has the SQ of the older subs... where the original momo faltered, i've been hoping this one will pick up the slack.
its not a repalcement for the "big" momo, its just another momo line... which is good... variety is nice.
*twiddling fingers*
i want those subs... grrrr....
anybody wanna buy my girlfriend's subs? so i can buy the new momo's ???? pleeeeease? lol.The Artist formerly known as PoweredByDodge -
by the way 160 for a GNX is about as bad as getting a caddle prod in the rear.. ya know?
question though -- what kind of power does your amp put out?
if your amplifier does not put out probably at least 300 x 2 at 4 ohms or 600 x 1 at 2 ohms, then you probably wont be able to adequately run the new momo subs without getting a new amp.
so that's something you'll wnat to think about before u go spend money on new subs -- even tho i think the new ones are much better, you still have to think whether or not they'll jive with your amp.The Artist formerly known as PoweredByDodge
