Speakers
rbasilk
rbasilk Posts: 2
I bought some PolkAudio speakers RM6750. I can't find info on them.Are they good I payed $159.00 for them.They said they are discontinued.
Also I need brackets.Thanks
Post edited by rbasilk on
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited June 2009
    The RM6750 is basically a HTIB (Home Theater In A Box) minus the AVR. They are basically 8 ohm speakers with an operating range of 20-100W per channel and the sub is an 8" sub with 50W continuous and 100W peak power capability. If you paid $159 for them brand new I would say that is about right. What AVR are you using to power them? As for brackets you can wall mount them right out of the box using the keyhole slots on the back of the speakers. If you want more adjustability I would try the Omnimount 10.0 or even something like the B-Tech BT33 or the Pinpoint AM25. Don't have any experience with any of these mounts, but they were the "recommended" choices after a quick Google search. Good luck and maybe someone with more experience with these speakers can make a better/more educated suggestion for you. Welcome to Club Polk.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • rbasilk
    rbasilk Posts: 2
    edited June 2009
    Thanks, I am new at this. I Have A Yamaha RX-V365. I plan on upgradeing later.I guess it is kind of cheap but sounds good when i hooked tuner up. The geek squad will hook up the rest tommorow. Thanks
  • wutadumsn23
    edited June 2009
    Looks like that Yammy will do just fine, 100W per channel x 5 channels. Geek squad, what do you need those guys for? lol. Cheap or not if it sounds good to you and it does what you want it to do that is all that matters.
    HT Rig
    Blu-Ray- 80 GB PS3
  • messiah
    messiah Posts: 1,790
    edited June 2009
    Tell Geek Squad to stay home! Do it yourself. It's easy, and you will learn something about your system.
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • wutadumsn23
    edited June 2009
    messiah wrote: »
    +1,000,000 Geek Squad is a waste of $$$$. Nothing tricky about hooking up a HT, if you get stuck we will be glad to help..... free of charge, lol.
    HT Rig
    Blu-Ray- 80 GB PS3
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited June 2009
    messiah wrote: »
    x 1,000,000,000
    Hooking up a HT system isn't as complicated as it might seem. It's pretty self explanatory really.
    If you have any questions, there are many people here willing to help.
    Like messiah said, doing it yourself really helps to familiarize yourself with your system. Plus you'll save some money(I'm sure The Geek Squad isn't too cheap) to put towards something else in your system.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • wutadumsn23
    edited June 2009
    I was in BB and an elderly couple was paying $100 (which I think is Geek Squads minimum charge) to come to their house and set up a Logitech remote. I was like are you serious???? Man, I am gonna get out of the Air Force and work there, lol.
    HT Rig
    Blu-Ray- 80 GB PS3
