BORING Question...Cleaning CD's
xandra
Most device manufacturer's tell you not to use solvents on CDs/DVD's -- that's nice but what should you do about smudges, dirt spots etc that don't come off with water/soft cloth. (I take extraordinary care with my disks and most are flawless... but real life happens.)
I've bought disc cleaners in past but have been too intimidated to use 'em.
Can anyone recc'd a 'safe' dvd/cd cleaner?
LR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
Post edited by xandra on
Add a little baby shampoo to lukewarm water, rub with a soft cloth then rinse. If that doesn't work use Isopropyl alcohol on a soft cloth. There is no need for any of the commercial cleaners or machines."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
I run mine under a faucet and then use a drop of liquid hand soap and rub them gently all over with the soap suds to give them a nice squeaky clean shine.
To dry them, I lay them on a flat paper napkin and press down which quickly absorbs all the water with no rubbing required. -
Thanks all: one of the great mysteries of life... solved.
much accomplished here today.LR Setup:
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability. -
I too use isopropyl alcohol and water - it works really well, especially on rental DVD's and CD's that I've lent to people and got back scratched.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
I use a chamois on all my equipment and my media.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
can i put some isopropyl in small spray bottle and spray it on the disc and then wipe dry?Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
starkiller wrote: »can i put some isopropyl in small spray bottle and spray it on the disc and then wipe dry?
Id mix with some water as well and use soft cloth. I wear glasses so i use the cloth to clean those and works quite well
PaulyLife without music would♭ -
That's a good idea too! We use such materials to clean our eye glasses.
i wonder what the ratio should be between the alcohol and water?Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Just make sure you rub on the radii.
I run Netflix DVDs under tap water and wipe it off on my t-shirt, or sweat pants. Worked fine so far in making a non-playable disc playable.
However, I have these products on order. Once it arrives and I have a chance to try them I will post a review.
http://www.mapleshaderecords.com/audioproducts/mikrosmooth.php
http://www.mapleshaderecords.com/audioproducts/optrix.php
http://www.mapleshaderecords.com/audioproducts/silclear.phpLumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I gotta check my new Mapleshade catalog to see if Pierre has any special formulas for cleaning 78s. -
hearingimpared wrote: »I gotta check my new Mapleshade catalog to see if Pierre has any special formulas for cleaning 78s.
Nope. Just 38s, 45s, and 9mm.
spit and wipe on your shirt. always worked for me
QUOTE]
Thank you! I do too
Under tough situations a drop of Dawn dishwashing detergent (or whatever is at the kitchen sink) will do too. 'just rinse them off before drying with dish cloth/shirt/pants or paper towel.
I have never lost a CD or a DVD. The best practice is to handle by the edges and to right away replace them into their jewel case. My kids never learned the latter, but are quite good at the former. Hence, the developed skills with clothing worn and detergent use! -
This is a little off topic, but I rented "The Bucket List" DVD recently and it had a major scratch across it, causing the disc to skip. I went and put a small amount of Maguires automotive scratch removing compound on the disc and buffed it out a couple times with a soft cotton cloth. Stuff worked beautifully, restored the disc and it played perfectly without a single glitch.
Thanks for the tip!! Guess that got that dvd off the bucket list too lol"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
messiah, November 23rd, 2010
