Looking under the hood
mhardy6647 wrote: »speaking of dump finds: Howzabout a vintage (1984) "silver-faced" Sony CDP-111. What a monstrosity.
As found, complete with the ingested Kenny G holiday CD :-P
http://www.thevintageknob.org/SONY/sonyes/CDP456ES/CDP456ES.html
too much egg nog i guess:DPolk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
My Denon POA-3000 Class A (push pull Class A) amp with 180WPC continuous into 8 ohms.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
Here is the beefy Integrated AMP Pioneer made over a decade ago.
Pioneer Elite A-91D Integrated Amp with 120WPC into 8ohms.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
That is a beefy piece of hardware.
I vote this thread as the best on the forum right now.
As i wondered through every page i was just in awe of how you guys are so into this.
A guy can really get into audio and want to try out other gear and "think" it's a hobby, Boy do i stand corrected. you guys deffinetly enjoy this hobby, as i went through the pages i was like "how do these guys find the time for all this" Amazing simply Amazing.
With the refurbishing and upgrading i am doing on my SRS 1.2's and trying to understand it all. + Ben is doing the real upgrade for me on these. It is very small to what some of you guys know and build. I am very humbled by what i have just read and saw.
Great work and a great read.
Larry. -
That's cool... -
My $25 mono bloc from Hong Kong.:eek:It's 3x LM3886's in parallel.Testing
Testing
Testing -
Those are some serious gonads!!!;) I think I have a cap fetish... -
TOOLFORLIFEFAN wrote: »I vote this thread as the best on the forum right now.
Larry.
I consider it one of the best one the net! Many products have been featured here. It is an excellent read for sure! -
$25 is a giveaway considering the size of the heatsink the PCB. Three LM3886 are just a freebie that comes with it.
3 x 38W @ 8ohms should be able to push some serious mid-sized woofers.
The heatsink was'nt included, I threw it on for testing purposes but still $25 isn't bad for a comlpete pcb with the LM3886's installed.In testing it put out about 80 clean watts into 4 ohm's which should be plenty for driving the woofer section (a pair of 6.5" Vifa's)of my active center channel.$25 is a giveaway considering the size of the heatsink the PCB. Three LM3886 are just a freebie that comes with it.
With four of these boards you can contruct a nice pair of economical,high powered mono blocs in the bridged parallel configuration(BPA300).Like thishttp://www.diyaudio.com/forums/showthread.php?s=&threadid=65131&perpage=25&pagenumber=1Testing
Testing
Testing -
mhardy6647 wrote: »That is a beefy piece of hardware.
Thanks for the complement, mhardy! A91-D has very open and very natural sounding amp with Digital Direct Input from CDP. I could listen to it all day long without fatigue and it makes a really nice two channel amp for the office.speakergeek wrote: »Those are some serious gonads!!!;) I think I have a cap fetish...
Yep! Men are known to go wild for for Caps Cans and Beer!
Thanks for the linky GV! I think this small wonder is capable of up to 150W into 8 ohms with the higher rails voltage. From what I read about LM3886, I believe you need external protection circuitry to go with the amp board? The BPA300 looks cool.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
When paralleled(not bridged) their output capability into 8 ohms will not be much more than that of a single chip.However the extra current output capability when paralleled does give them more output potential into 4 ohm loads.I confirmed this with an a distortion anylizer.Output into 8 ohms was roughly 50 watts and 80 into 4 ohms with +-30 volt rails.The voltages could be increased but heat disipation and reliability become issues.think this small wonder is capable of up to 150W into 8 ohms with the higher rails voltage.
You could add on DC protection for speakers but it's not essential.The chip has onboard overload and thermal protection.from what I read about LM3886, I believe you need external protection circuitry to go with the amp board?
It does if I needed another amp I think would try one of these for fun.The BPA300 looks cool.Testing
Testing
Testing -
When paralleled(not bridged) their output capability into 8 ohms will not be much more than that of a single chip.However the extra current output capability when paralleled does give them more output potential into 4 ohm loads.I confirmed this with an a distortion anylizer.Output into 8 ohms was roughly 50 watts and 80 into 4 ohms with +-30 volt rails.The voltages could be increased but heat disipation and reliability become issues.You could add on DC protection for speakers but it's not essential.The chip has onboard overload and thermal protection. It does if I needed another amp I think would try one of these for fun.
I know you've measured it but I wonder why there is not much more power through 3 x LM3886 than a single LM3886. Could the caps be limiting factor for the amount of current 3 x LM3886 can handle?Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Pass Labs X250. 100 lbs of beauty.
Very Cool Amp, Ricardo!Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
Nice amp Ric.
The white stick on labels must indicate the matching of the IRFP240/924O output MOSFET's.If a set needed to be replaced they could be matched accordingly.Pass Labs X250. 100 lbs of beauty.
Testing
Testing
Testing -
It's a voltage limiting thing not current limiting.In fact operating 3 of them in parallel means that there is morecurrent available to drive lower impedances.The voltage swing will be no different than as with a single chip.For increased output into 8 ohm's you could bridge a pair of chips which would increase the voltage swing.I know you've measured it but I wonder why there is not much more power through 3 x LM3886 than a single LM3886. Could the caps be limiting factor for the amount of current 3 x LM3886 can handle?Testing
Testing
Testing -
From the shallow end of the gene pool... a late 1960s EICO solid state receiver. Not in the same league as the wonderful EICO tube stuff, but I couldn't pass it up for the price of shipping. Apparently I've never posted these photos to this thread....(?)
and a Sansui TU5500 I found at the dump.
Nice Vintages, mrh! Congrats on the nice find.
iPhone pic of the guts of my Hsu ULS-15. Figured I'd take a shot of it before I send it n for replacement.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
In terms of audio, i truly feel sorry for the visually impaired. How can they know what they like if they cant read google?
http://www.polkaudio.com/forums/showcase/view.php?userid=86838 -
Once again we meet at last.
Wow thats some serious iron and caps, for a "plate amp".
Dave
Hehehe. you'd be horrified to know i pulled them out and drilled holes in the bottom, and fed speaker cable direct to the drivers then.... lolIn terms of audio, i truly feel sorry for the visually impaired. How can they know what they like if they cant read google?
This bad boy's on my bench with a poached channel.Interesting but simple design using Jfet's,BJT's and Mosfet's for the output's.Testing
Testing
Testing -
Testing
Testing
Testing -
bump
