keepin your receiver cool
slowpolky
i would like some info on the various types and costs of cooling fans for a receiver, what fans are better than others and why? also why does a receiver sutch as the onkyo's run hot in the first place, are they so powerfull? or do they use cheap components whilst manufactored. your input is deeply valued friends
Post edited by slowpolky on
i JUST placed a basic computer fan on top of my yamaha to keep it cool while playing loud. but it's a loud fan and it might have to go. you can probbably find a good quiest computer fan and find a 12V power supply for itIn-Car:
Head Unit: Sony MEX-1GP
Door speakers: Infinity Kappa 680.9cs
Rear speakers: Polk db690
Subwoofers: Memphis Audio 15-M3124
Amps: Pioneer GM5300T, Kenwood KAC 6020, Memphis Audio MCD1.1100
In-Home:
Harmon/Kardon AVR 230
Harmon/Kardon DVD 101
Yamaha RX-V995
Bose 161
Bose 901
Polk FXi30 -
try newegg.comIn-Car:
In-Home:
Yamaha RX-V995
Bose 161
Bose 901
Polk FXi30 -
I think the onkyo's run hot because of the chip that does the audio processing. When I run mine in just stereo mode, it is cool as a cucumber. I can't say if the chip is cheap and would be cooler if it was better quality, but I think the chip is the culprit, unless you are really running at reference levels. FWIW"Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason." -
Be aware that newer silver-faced HK receivers are prone to failure because of this exact thing - they require extra cooling on the main processor. Some guys I know are using dual-fans on their receivers.
By the way, use the rheostat (variable resistor) to slow down your fan and make it more quiet, or use a quiet fan like Panaflo Lo.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
They make small mag-lev fans if you are really worried about the sound, or just run a variable PC fan at a lower voltage to help keep the noise down; that has worked well for me in the past. Another option is, I installed a thermostat on my Carver amp so that the fan only turns on when the unit gets warm enough. In normal use, the fan kicks on about every ten minutes for about a minute or two.
i installed a mains fan into an old sherwood amp i use for house partys :-) , it does the trick but its mega loud.
before that i just placed a large pc fan with low rpm's on top , that was still a little loud, i can remember reading a manual for something once, it said that if the unit got hot you should point a fan at it :-) , seems logical for the short run.ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
short run is cool ,lol, but i only use it for movies hooked up to my pj, so its gota be super quiet ,my 607 is black ,even though the wife wanted a shiney silver 1 lol, imagine how that would work for darkroom movie going right under the screen so thank goodness i never got silver. It baffles me why only the silver would overheat? but i do know that after 2 hours sandwiched in the marantz 7001 cab that this things ready for eggs and bacon
The 600s, in particular, make good space heaters! Best have them in an A/C room in the summer. I don't use a fan on mine I just keep it on the top shelf WITH NOTHING but 6-7 feet of air above it and NOTHING on either side. It still heats up but It's never failed or shut-down..and it's been running for almost 2 years!
i left it powerd on last night and it was way hot today when i got home, even though there was nothing gettin passed through it, it makes me anxious that i may be shortening the life span
I know people who've had Onkyos for several years...all of them heat up like mine, yours...I wouldn't worry too much but a fan can't hurt. That heat builds up mostly over the video section...why? I'm not sure....there are some comments above....but I find my 605 can heat up in even 2 channel so I doubt it's the processing.
Make an adapter for a variable(thermistor)120mm puter fan to run off the 12v trigger? Just make sure the fan doesn't exceed the amp rating on the trigger.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
That's a very good idea Ben! But I don't think the newer units have the 12v...you have to be in the 700 series or higher. Some older 600s had a switch/electrical input that could be used to about 100 watts or so! But I don't think the 607 slowpolky has does. Every year Onkyo gives you something more and TAKES something AWAY in their mid-line. Who wouldn't want electrical outlets in the back of their receiver...my Denon has 2 and a 12v Trigger, and 8 pre-outs?
I think this was talked about before, but is it better to pull hot air out of the unit or blow cool air into the unit?
Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
intresting concept knucklhead, how would one suck it out ?
I think he was asking if is is better to blow cooler air into/around the unit or set it up as an exhaust for the area or the unit.
I think this is a fair question. -
guys my brand new marantz equip cab has started melting and i just bought it, the vynil on the front face is bubbling up from the parti board
Dont burn your lips my friend!:pPolk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
I just put sunglasses on mine.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
wingnut4772 wrote: »I just put sunglasses on mine.
it appears from your sig, your equip is already pretty cool!;)Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
I run mine in the fridge next to the milk.
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Nailed it! -
Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
Knucklehead wrote: »I think this was talked about before, but is it better to pull hot air out of the unit or blow cool air into the unit?
I'm definitely no expert, but here's my 2cents. It would seem to me that the fan would work best mounted on top pulling air instead of blowing air on the receiver. All of the heat rises, so if it is on top wouldn't it be pulling the hot air out while pulling cooler air from the sides and back? Makes sense to me, but so do crazy people:DSony 40" LCD
Sony DVPCX995V
Sony PS3(games/media server)
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
When rapture comes, can I have your car? -
I bought a comp. fan to remove hot air from the cabinet where I have my Pioneer receiver and PS3. What do I need to make it work with the 12v trigger?
I try rigging it up, but the receiver gave me a 12v trigger error message. Do I need some kind of resistor?HT:
Projector - JVC HD100, 100" Fixed Screen, A/V Receiver - Pioneer Elite VSX-92TXH, Power Conditioner - Panamax M5300-EX, BluRay - Sony PS3, (2) ADCOM GFA 555 Bridged, Speakers - LSi 15, LSi C, LSi FX, Sub - 12" M&K VX-1250.
Living Room:
Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7 -
Why not attach a more efficient heatsink with some artic silver? That would do better than any fan, or much better with a fan.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
rallyshark wrote: »I'm definitely no expert, but here's my 2cents. It would seem to me that the fan would work best mounted on top pulling air instead of blowing air on the receiver. All of the heat rises, so if it is on top wouldn't it be pulling the hot air out while pulling cooler air from the sides and back? Makes sense to me, but so do crazy people:D
I thought the same thing, but tested both ways with a simple blower type fan. I think you will only see a benefit by drawing the hot air out of the cabinet is if the cabinet is completely enclosed. My cabinet has the back mostly open and a glass door (which since I have taken off) and trying to pull the hot air out did nothing. I then reversed the fan to blow the hot air off / out of the front of the cabinset, and that worked better. Here is a good site with information and products on several ways to do it:
http://www.coolcomponents.com/ -
Thais for the link.... I opened the back of the cabinet, but I want to move the air in it, mainly blow it out.HT:
Living Room:
Great thread, I'm always scared the soddering is gonna melt in my avr
