Cleaning dirty/dusty drivers
    F1nut Posts: 51,783
    edited June 2009
    Silicone is nasty stuff. It migrates like crazy and will cause electrical connections to fail. Used on furniture/speaker cabinets it builds up and leaves smudge marks. In addition, if the item ever needs touch up, it makes doing so a total nightmare.
  • shack
    shack Posts: 11,154
    edited June 2009
    CowboyRJB2 wrote:
    NO, not for my auto... For my SDA 1C's and M10's... I dont drench them. I spray the cloth lightly and give the drivers a wipe
    I wouldn't put armorall on any part of my 1Cs...but especially not on the driver cones! That stuff will damage the material and mess up your speakers.
  • CowboyRJB2
    CowboyRJB2 Posts: 58
    edited June 2009
    I hear what you're saying, but others and myself use Windex.. The ammonia and whatever soap that is in Windex cant be any better for the cones than Armoral.
    Just a very light wipe with Armoral takes away the slight stickiness to the drivers. I do it like once a year... Like I said, I spritz the rag, not the cones and then wipe them.I keep my grills ON....
    ELITE VSX-99 REFERENCE
    ELITE PD-65
    SDA-1C's with new RDO194-1 tweeters as MAINS
    MAGNEPAN TYMPANI 1D's for alternate fronts for classical music
    PARADIGM REFERENCE CC-450 Center
    MONITOR SERIES II... M10 REARS
    2 POLK DSW-600PRO SUBS
    "ROCKIN THE HOUSE"
    F1nut Posts: 51,783
    edited June 2009
    Ummm.... the cones are suppose to be sticky.
    Again, Windex will not harm the drivers or the surrounds, period.
  • nspindel
    nspindel Posts: 5,343
    edited June 2009
    :eek:
    Toolfan66 Posts: 18,066
    edited June 2009
    I only used it one time. It was not armor all but it had silicon.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2009
    Oh boy, now your speakers are going to get leprosy:D
