Passive pre amps
  • steveinaz
    steveinaz Posts: 19,545
    edited May 2009
    If I ever went passive again, it would be another Placette. The level control in the Placette is the real winner---absolute linearity, at any setting.
    At first I thought "a thousand bucks for this thing? You gotta be kidding." After I bit the bullet and bought/listened to one, that changed to "only a thousand bucks for this thing? You gotta be kidding."
    Seriously.
  • Systems
    Systems Posts: 14,872
    edited May 2009
    Face wrote: »
    It's an older Goldpoint stepped attenuator in a custom case.
    Is it a 10k ohm or 25k ohm or higher?
    Testing
    Testing
    Testing
  • Face
    Face Posts: 14,340
    edited May 2009
    The one pictured above is 10k, I'm not sure what my others are.
  • strider
    strider Posts: 2,568
    edited June 2009
    Mike or Jake -
    Would replacing the volume pot in my B1 be as simple as replacing it with a stepped attenuator of similar ohm rating?
    Wristwatch--->Crisco
  • Face
    Face Posts: 14,340
    edited June 2009
    Yes, I believe so.
