Hafler dh100
ROY BOY
ROY BOY Posts: 89
edited June 2009 in 2 Channel Audio
Hi every one. Today one of my friend bering over one used Hafler HD100 pre amp to do test. when I hook up whit my power amp and SDA SRS that sound so good. Now I need to know if I can have some thing like that whit remote . I like to have that kind of sound . Any info will be nice. Thanks Roy
Post edited by ROY BOY on
    edited May 2009
    It's kind of hard to follow you. If you're saying can I get a pre-amp with a remote. The answer is YES. I'm not familiar with Hafler pre-amps, though I have heard Hafler amps and I've always liked them!
    Perhaps some one else knows that pre-amp?
    cnh
  • fbm211
    fbm211 Posts: 1,488
    edited May 2009
    Call john and maybe he can help you out...http://www.musicaldesign.com/contact_us.htm
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • sucks2beme
    sucks2beme Posts: 5,690
    edited May 2009
    There's some decent cheap 2 channel preamps out there. Some
    Parasounds like the psp-1000 or 1500 had a very good 2 channel bypass
    with remote. There are some Rotel and Nad models, too. But, of course,
    the bulk of 2 channel preamps don't have remotes. As one Stereophile
    reviewer put it, we didn't have remotes back then, and we liked it that way!
  • ROY BOY
    ROY BOY Posts: 89
    edited May 2009
    cnh wrote: »
    cnh
    I was asking in new model pre amp can give sound like Hafler HD100. Because I like to have some thing whit remote. I know it hard to find some thing like that. thanks
  • Stevenmbell
    Stevenmbell Posts: 60
    edited May 2009
    Roy Boy
    Have you ever tried B&K PT3 it has a remote and a tuner used you can find them for$200.00 to $250.00 A very good deal if you ask me. I love the sound from mine.
    2 CHANNEL:cool:
    Belkin PF31Pure power/AV Conditioner
    NAD C165BEE PreAmp Great Phono Section
    B&K ST1400 S2 Power Amp
    Audio Quest 4 Speaker Cables
    ProJect RPM 1 Carbon
    Ortofon Blue Cartridge
    Quadio Interconnects
    Denon 2910 DVD-A/SACD Player
    Pangea SE 14 & AC9 Power Cords
    Vifa DIY 3 ways Sound is incredible. :biggrin:
  • ROY BOY
    ROY BOY Posts: 89
    edited June 2009
    Roy Boy
    No I have not try that model. But I will look in to it. My power amp is Adcom 5800 and speakers are SDA SRS. Have you or any one else had try that pre whit that amp ?. Thanks Roy
  • ViperZ
    ViperZ Posts: 2,046
    edited June 2009
    I have had great sound with Carver CT-28v preamp. Yes, it's a 5.1 preamp, but it has a stereo mode.. and the other advantage of using such a preamp is that you can hook up a sub to it, so you will have a 2.1 setup.
    Adcom preamps also have remotes, but again, most are 5.1 with 2.1/2.0 options.
    My Marantz AV550 DD preamp also has a direct stereo mode... so you have a lot of choices.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
