DVD Authoring Software
AsSiMiLaTeD
AsSiMiLaTeD Posts: 11,728
edited June 2009 in The Clubhouse
I'm looking for a good, inexpensive dvd authoring program. I don't need anything super high end. All I want to do is be able to take photos and put a dvd together with music and have some control over menu options and letting people choose between sets of photos.
Something like DVD Maker in Windows Vista, but with a bit more flexibility in letting me create menu options for various groups of photos.
Anyone got any suggestions?
Post edited by AsSiMiLaTeD on
    treitz3 Posts: 20,076
    edited May 2009
    Have you looked at Movie Studio Plus? It's not cheap [got mine for $200] but it will do what you said you want and then some. You could probably find it online a lot cheaper.
    edited May 2009
    Ooops. My apologies. It's called Studio Movie Board Plus and it's made by Pinnacle.
  • AsSiMiLaTeD
    edited May 2009
    I will take a look, but I was thinking something closer to 50 bucks
  • tcrossma
    tcrossma Posts: 1,301
    edited May 2009
    I've used Roxio Easy Media Creator and while it's not perfect, it does a pretty good job. It should be in your price range.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
    edited May 2009
    I've use Roxio and it's OK...if you want to do entry level stuff which sounds like it. I've recently been messing around with video conversion software and I can't tell you how incredibly complex and confounding some of that stuff...talk about a zillion formats....holy Batman! You can waste weekends trying to figure out what can compress this or that and what can unpack this and that. It's really a crying shame and a spectacular waste of time unless you're a member of nerds-are-us!
    cnh
  • zeppage2
    zeppage2 Posts: 196
    edited May 2009
  • AsSiMiLaTeD
    edited June 2009
    I found the Sony DVD Architect Studio on that page, I'll give it a try. I was really hoping for something that's as simple to use as Windows DVD Maker. Hell, if Windows DVD Maker would just give me the ability to make my own chapters it would be everything I need and nothing more...
  • Sami
    Sami Posts: 4,634
    edited June 2009
    Free software:
    http://www.kinodv.org/
    http://dvdstyler.de/
    http://qdvdauthor.sourceforge.net/
    This has a lot of features but is NOT easy to learn, from what I have heard:
    http://cinelerra.org/
  • ckphoto
    ckphoto Posts: 121
    edited June 2009
    Ulead DVD MovieFactory is what your looking for it is cheap and will do exactly what you are looking for http://www.ulead.com/dmf/runme.htm there is a free trial so you can see if you like it.
    Mitsubishi WD-73736
    Pioneer Elite SC-05 :D
    Xbox 360
    Sony PS3 80GB
    Velodyne minivee
    Rti70s
    Csi40
    4-Fxi50s
    Monster PowerCenter HTS 3600 MKII
    Harmony One
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited June 2009
    I use TMPGEnc 3, very advanced features, also great for creating Divx files, and Blu-Ray. It was $69, when I got it, version 4 is $99, but you get a $20 Amzon gift card. There is a free trial version too.
    http://tmpgenc.pegasys-inc.com/en/product/taw4.html
