Carver/SRS 1.2TL
Big Dan R
Can anyone tell me if a Carver M1.5T amp is compatible with the Polk SRS 1.2 TL's? Ive heard unofficially that there might be a common ground incompatability. The power rating is 350/ch
Thanks,
Dan
Thanks,
Dan
Post edited by Big Dan R on
From a previous thread......
"One of the things that George and I talked about this weekend was using Carver and SDA. It would appear from George's literature (he sold Carver products for a while, with that damn fine butt of his) that the Carver m1.5t IS fo' sho' a non-common ground amp (I knew that) but it is also the ONLY non-common ground amp. So if you are using anything other than the m1.5t with your SDA's, you should be good to go."
BDT
You will need to use the AI-1 interconnect cable or build one using a isolation transformer.Political Correctness'.........defined
President of Club Polk -
So what does that mean??
Dan -
Welp, two things: sounds like you don't want to use the Carver M1.5T with the SDA's, and George has a killer **** ... the latter of which seems most significant.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
It simply means that you need to use the AI-1 interconnect cable or make one. You will not be able to use the Carver with the SDA's without either. Of course, you could get a different amp which is a common-ground type and that would solve your problem too.
For the record, I haven't nor do I desire to see George's ****, that statement was from Troy and I've got no idea what the two of them have going on.Political Correctness'.........defined
What exactly is this AI-1 cable and how is it connected? How much does one cost? I guess at this point I would rather go with this cable than get another amp. I can make an amp change in the future if im not satisfied with sound quality.... I just bought the SDA's and have not gotten them yet.
Dan -
Dan,
You've got mail.Political Correctness'.........defined
Again I have to say that I ran my SRS's on a M-1.5t for ten years with just the standard SDA IC and no problem.
I owned a M-500t and returned it as it was not a common ground design and got the 1.5t, which I was told was a common ground design.More later,
Tour...
Vox Copuli
Thanks Tour for the good news, now I have to get my cable selections, ie speaks, component inters and of course the TL's, and rock on...
BTW, was born in Cleveland!
BDR
