My Polk RT1000p refinish
ViperZ
Original Polk RT1000p towers are very very ugly (sorry Polk), especially with that felt material stuff glued to the front.
After many years and a few moves that felt material looked like crap, the speakers had some dents in them, so I have decided to refinish the cabinets.
First, that multi-layer black paint finish on the sides is another piece of crap. Took me forever to remove it.
Anyway, here is the final result. Red Chestnut finish on the birch veneer.
Before (last year):
Today:
Now please convince me to start working on the CS400... :mad:
Before (last year):
Today:
Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
B&W CDM1-SE fronts
B&W CDM-CNT center
Post edited by ViperZ on
They look a thousand times better!!
Great job, now get busy on the CS400 LOL -
DAMN! nice job!
Nice Job!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
whollly SHEEET!!! those look fantastic, and far more expensive looking than the originals.
Way to go...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Those look amazing! Really rich color.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
Very nice...go ahead and finish your center before you get outa the notion.
I need to veneer my CRS's some day...I like the looks of your stain and wood combo...very rich. -
Well done Viper! That is an inspiration for me to do the same with my "Black" RTi100's. What finish remover did use? Did you try several different types?
Thank you very much for all the kind comments!
(by the way, Maggies MGII and JBL subwoofer in the background were completely rebuilt too :rolleyes:)
Regarding finish remover, it was mostly elbow grease. Well, 50-grit sand paper on a rotating grinder attachment to the hand drill. I'd have to say - a lot of sand paper. This type of finish is just a very thick (or multiple thin) layer of a black paint.
On the other hand, CS400 uses simple vinyl finish on the sides, which is easy to remove (hopefully). CS400 also uses hard wood(?) for the front part of frame.
If anyone knows how to remove a power port cover on CS400, please let me know. It seems that the screws are under some kind of felt material, which is glued in place. It would be a shame to rip out that stuff and not finding the screws.
Bigger photos, which show the finish better:
http://farm3.static.flickr.com/2453/3574970028_d75d55a00e_b.jpg
http://farm4.static.flickr.com/3578/3574162543_5da12f30c0_b.jpgPanasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
I can't even imaging taking the foamy stuff off those speakers... You have the skills and patients good sir.
Now that is what I call a refinished. You did it RIGHT.
Those look absolutely AWESOME!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Beautiful, just beautiful....
Great satisfaction comes from great deeds.In terms of audio, i truly feel sorry for the visually impaired. How can they know what they like if they cant read google?
http://www.polkaudio.com/forums/showcase/view.php?userid=86838 -
They look very nice.Political Correctness'.........defined
President of Club Polk -
Thank you!!
Stained the CS400 today... Polyurethane tomorrow...
I didn't like the way the tops of those RT1000p looked (not perfect!), so removed the tops (took me like 3 hours to do it carefully) and replaced the tops. Staining tomorrow.Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
All righty... I think I am done with these:
B&W CDM1-SE fronts
B&W CDM-CNT center
You removed the black a on the sides and foam in the front. Is/was it real wood underneath it?
Amazing work! They look way better than the original judging by the pictures! How have they been holding up for the last 3 years?
I had a similar issue with the look of mine as well (although they were the cherry cabinet which didn't go with anything else in our living room) and ended up going with black suede. I'd still like to refresh the bases a little but at least now they're presentable!
-Ryan
Receiver: Denon AVR2112CI
Center: Polk CS350-LS
Fronts: Polk RT1000P
Rears: Polk RT1000P
Sub: Polk PSW-404 -
Nice work! I like the new finish better!Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
This.... ^^ They were real wood on the inside? -
slider2828 wrote: »This.... ^^ They were real wood on the inside?
Never answered this question... No, they are not real wood underneath. I used birch veneer to refinish them - top, front and sides.Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
Nice Job!Samsung UN55C6500 55" LED
Onkyo TX-NR3007
Polk Audio RT5000
-RT3000 front
-CS1000 center
-FX1000 dipole
Polk Audio PSW1000 5.1 sub
Polk Audio microPRO 4000 x2 5.2 subs:biggrin: -
Hello new here just to get more feedback, I can get a complete set with the polk audio cs400,two fx500,and two rt100p for $300. I know they are very old but in good shape is this a good deal?
