My Polk RT1000p refinish
ViperZ
ViperZ Posts: 2,046
edited June 2013 in DIY, Mods & Tweaks
Original Polk RT1000p towers are very very ugly (sorry Polk), especially with that felt material stuff glued to the front.
After many years and a few moves that felt material looked like crap, the speakers had some dents in them, so I have decided to refinish the cabinets.
First, that multi-layer black paint finish on the sides is another piece of crap. Took me forever to remove it.
Anyway, here is the final result. Red Chestnut finish on the birch veneer.
Before (last year):
Today:
Now please convince me to start working on the CS400... :mad:
Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • zarrdoss
    zarrdoss Posts: 2,562
    edited May 2009
    DAMN! nice job!
  • danz1906
    danz1906 Posts: 5,144
    edited May 2009
    Nice Job!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
    nooshinjohn Posts: 26,184
    edited May 2009
    whollly SHEEET!!! those look fantastic, and far more expensive looking than the originals.
    Way to go...
  • zingo
    zingo Posts: 11,258
    edited May 2009
    Amazing!
  • dpowell
    dpowell Posts: 3,082
    edited May 2009
    Those look amazing! Really rich color.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited May 2009
    Very nice...go ahead and finish your center before you get outa the notion.
    I need to veneer my CRS's some day...I like the looks of your stain and wood combo...very rich.
  • ViperZ
    ViperZ Posts: 2,046
    edited May 2009
    xcapri79 wrote: »
    Well done Viper! That is an inspiration for me to do the same with my "Black" RTi100's. What finish remover did use? Did you try several different types?
    Thank you very much for all the kind comments!
    (by the way, Maggies MGII and JBL subwoofer in the background were completely rebuilt too :rolleyes:)
    Regarding finish remover, it was mostly elbow grease. Well, 50-grit sand paper on a rotating grinder attachment to the hand drill. I'd have to say - a lot of sand paper. This type of finish is just a very thick (or multiple thin) layer of a black paint.
    On the other hand, CS400 uses simple vinyl finish on the sides, which is easy to remove (hopefully). CS400 also uses hard wood(?) for the front part of frame.
    If anyone knows how to remove a power port cover on CS400, please let me know. It seems that the screws are under some kind of felt material, which is glued in place. It would be a shame to rip out that stuff and not finding the screws.
    Bigger photos, which show the finish better:
    http://farm3.static.flickr.com/2453/3574970028_d75d55a00e_b.jpg
    http://farm4.static.flickr.com/3578/3574162543_5da12f30c0_b.jpg
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • zingo
    zingo Posts: 11,258
    edited May 2009
    I can't even imaging taking the foamy stuff off those speakers... You have the skills and patients good sir.
  • Pauly
    Pauly Posts: 4,519
    edited May 2009
    Good job, they look OUTSTANDING
    Life without music would♭
    VR3 Posts: 29,762
    edited June 2009
    Now that is what I call a refinished. You did it RIGHT.
    Those look absolutely AWESOME!
  • polkie4life
    polkie4life Posts: 231
    edited June 2009
    Beautiful, just beautiful....
    Great satisfaction comes from great deeds.
    In terms of audio, i truly feel sorry for the visually impaired. How can they know what they like if they cant read google?
    http://www.polkaudio.com/forums/showcase/view.php?userid=86838
    F1nut Posts: 52,406
    edited June 2009
    They look very nice.
  • ViperZ
    ViperZ Posts: 2,046
    edited June 2009
    Thank you!!
    Stained the CS400 today... Polyurethane tomorrow...
    I didn't like the way the tops of those RT1000p looked (not perfect!), so removed the tops (took me like 3 hours to do it carefully) and replaced the tops. Staining tomorrow.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • ViperZ
    ViperZ Posts: 2,046
    edited June 2009
    All righty... I think I am done with these:
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • Deepc6
    Deepc6 Posts: 21
    edited May 2012
    You removed the black a on the sides and foam in the front. Is/was it real wood underneath it?
  • Dark
    Dark Posts: 1
    edited May 2012
    Amazing work! They look way better than the original judging by the pictures! How have they been holding up for the last 3 years?
    I had a similar issue with the look of mine as well (although they were the cherry cabinet which didn't go with anything else in our living room) and ended up going with black suede. I'd still like to refresh the bases a little but at least now they're presentable!
    -Ryan
    Receiver: Denon AVR2112CI
    Center: Polk CS350-LS
    Fronts: Polk RT1000P
    Rears: Polk RT1000P
    Sub: Polk PSW-404
    SCompRacer Posts: 9,407
    edited May 2012
    Nice work! I like the new finish better!
  • slider2828
    slider2828 Posts: 118
    edited May 2012
    Deepc6 wrote: »
    This.... ^^ They were real wood on the inside?
  • ViperZ
    ViperZ Posts: 2,046
    edited September 2012
    slider2828 wrote: »
    Never answered this question... No, they are not real wood underneath. I used birch veneer to refinish them - top, front and sides.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • chris23120
    chris23120 Posts: 95
    edited April 2013
    Nice Job!
    Samsung UN55C6500 55" LED
    Onkyo TX-NR3007
    Polk Audio RT5000
    -RT3000 front
    -CS1000 center
    -FX1000 dipole
    Polk Audio PSW1000 5.1 sub
    Polk Audio microPRO 4000 x2 5.2 subs:biggrin:
  • c_nitty
    c_nitty Posts: 38
    edited June 2013
    Hello new here just to get more feedback, I can get a complete set with the polk audio cs400,two fx500,and two rt100p for $300. I know they are very old but in good shape is this a good deal?
