Advice on HT project appreciated
Zeatrix
Zeatrix Posts: 17
edited September 2013 in Basic Hookup/Wiring Questions
Thanks for taking the time to help me out with advice.
I've recently bought a Sony Bravia KDL-52W5500 and have now started looking at the audio part of my HT. Previously I've owned a Sony entry level 5.1 system that's been ok but I'm now looking to improve in that department.
Currently I'm leaning towards buying a Sony STR-DA3400ES receiver, Emotiva XPA-5 and Polk LSi15, LSiC and LSiF/X. This combination is stretching my budget and I'll probably be buying it in steps starting with the receiver.
The reasoning is that I've read a lot of good things about the Sony STR-DA5400SE (best in class according to What HiFi among others) and it's cheaper sibling seems to contains the same stuff except a weaker amplifier.
This is where the XPA-5 comes in since I'll need an external amp to power the LSi line anyways.
Now some parts I haven't worked out:
- Is anyone aware if there are any other differences between the 3400 and 5400 receivers except power?
- I have three options for setup (I think):
  1. Use the XPA-5 to bi-amp the LSi15's and single amp the LSiC with the receiver handling the surrounds.
  2. Have the XPA-5 power each speaker.
  3. Go for the XPA-3 instead and only single amp the fronts and center channel once again letting the AVR handle the backs.
I've read the manuals for the receivers and I think it's possible to bi-amp using the pre-outs (it is possible using the speaker outputs) but it's not entirely clear so if anyone can confirm or deny that I'd appreciate it.
Thanks for taking the time to read my thoughts/questions and any feedback is appreciated.
  • McLoki
    McLoki Posts: 5,231
    edited May 2009
    Option 2 is by far your best bet. Let the amp take care of all the channels. Don't worry about bi-amping for now and don't connect your Sony AVR directly to the speakers. (in my opinion)
    Welcome the Club Polk.
    Michael
  • Zeatrix
    Zeatrix Posts: 17
    edited May 2009
    Thanks for the input so far, please keep 'em coming :)
  • apphd
    apphd Posts: 1,514
    edited May 2009
    There is a 4th option. There are some true 4 ohm stable receivers out there if you want to go that route.
    Although I think the best economic way to go is a mid-fi AVR with pre outs and an amp.
    http://nadelectronics.com/products/av-receivers
    http://www.arcam.co.uk/products,fmj,av-amplifiers,AVR600.htm
    http://www.rotel.com/NA/products/index.htm?cat=24
  • dpowell
    dpowell Posts: 3,081
    edited May 2009
    Hi and welcome to the club!
    One quick question. Are you doing 5.1 or 7.1 surround? If you are considering 5.1, you can find really good used pre-amp/surround processors like Outlaw Audio's 950 or 990 series to connect to your external amp. You may find some savings that way which would allow you to put more bucks towards the external amp section.
    I've found that my Sony ES AVR tends to make my Polks sound a bit on the bright side but I don't have the LSi's so I'm not sure if that would hold true with a Sony/LSI combination.
    With regard to bi-amping, I highly recommend that you bi-amp the built-in subs on the LSi15's using the pre-outs from your AVR. I noticed a significant improvement in the clarity of the bass when connecting the subs on my RT mains that way vs connecting them with the speaker outs from the amp. In my setup, I use "Y" cables at the external amp connection to split the signal for the L/R mains to achieve this.
    Good luck with the setup!
  • dpowell
    edited May 2009
    BTW, go for the 5 channel amp vs the 3. Power all of your speakers with the external amp if possible. The change in dynamics and power is significant.
  • Zeatrix
    Zeatrix Posts: 17
    edited May 2009
    apphd wrote: »
    Yes, I would very much prefer an integrated solution, and the ones you suggested are great, but way over my budget (and what I'm willing to pay for a receiver). The Arcam isn't even sold in Sweden (yes I'm a foreigner).
  • Zeatrix
    Zeatrix Posts: 17
    edited May 2009
    dpowell wrote: »
    Thx for the response dpowell. I'm doing a 5.1 setup.
    Also, the quote above wasn't entirely clear to me. Could you maybe try to explain it differently to a foreigner like me :)
  • apphd
    apphd Posts: 1,514
    edited May 2009
    Zeatrix wrote: »
    I hear you, 4 ohm stable receivers come at a cost. What is your budget? Amps are usually pretty heavy, so don't forget shipping charges and tax if you are looking at something not avail. locally for you. Do you have anything in Sweden like Craigs List? Have you purchased the LSi's yet or have you considered some 8 ohm speakers? The LSi's would probably make you very happy, I just have no idea what the cost for powering them might be for you.
    Do you have some gears avail. to you there that we may not be familiar with here?
  • Zeatrix
    Zeatrix Posts: 17
    edited May 2009
    apphd wrote: »
    My budget on pre/pro+amp is around $2000 but I'd love to come in below that. That's why I'm considering the Emotiva XPA-5 since it seems to be really good value even though I have to add tax and shipping ($799 + 25% tax + shipping).
    We have similar things to craigs list (there is even a Swedish subsection of craigs list :p) but the selection is rather poor.
    I have not purchased the LSi's yet, I did consider the RTiA9 but they didn't look as cool and demanded heaps of power. And I was under the impression the LSi's was the top range which is what I'm looking for ;)
    Toolfan66 Posts: 18,408
    edited May 2009
    From my understanding the LSi's take a lot more to power then the A9's, I have the A9's, and i am using the XPA-3 to power them. and by the way they look very cool :) , and sound fantastic.
  • apphd
    apphd Posts: 1,514
    edited May 2009
    Zeatrix wrote: »
    Got ya. Does Emo ship to Sweden? What is your input power in Sweden? Sorry for my ignorance of your country, I've been lucky to spend some time in other lands but unfortunately Sweden was not one.
    As TOOL said the LSi is at the top of the current Polk line up, they not only require lots of power but current as well. The RTi A9 while needing some pretty good power to sound their best, @ 8 ohms do not need the current of the LSi's and many possible AVR's can drive them sufficiently.
  • dpowell
    edited May 2009
    Zeatrix wrote: »
    Sure! On the back of your AVR are the line level outputs for each speaker. These are the outputs on the the AVR that you run cables from to your power amplifer. In your case, you have Left and Right front speakers plus the center and rears.
    I have the same exact setup at the moment (AVR plus external 5 channel amp). For the center and rear speakers, I have the RCA interconnects going directly from the line level outputs on the AVR to the external amp.
    For the Left and Right main speakers (which have built-in subs and their own line-level inputs), I have a splitter or Y cable which I inserted to split the signal. One end of the Y plugs into the external 5 channel power amp and the other end of the Y runs to the line level input on the Left or Right speaker's subwoofer.
    Essentially what this does is avoid amplifying the signal twice, once at the power amp or AVR and another at the speaker's sub amp.
    I believe that there is a diagram in Polk's speaker manual for powered towers like the LSi's or RT3000's which might help you visualize this. The only thing is that I don't believe they show a setup with an external power amp where the Y cable is required.
  • dpowell
    edited May 2009
    Zeatrix wrote: »
    If you're not worried about getting the new HD audio formats, you could probably pick up a nice used Outlaw 950 pre for around $250 and that includes some shipping (or get the 990 for a few hundred more). From what I've heard, both are fantastic sounding processors. Not sure what it would cost to ship it overseas. It is a 7.1 processor so you'd be ready for the next step up down the road.
  • Zeatrix
    Zeatrix Posts: 17
    edited May 2009
    apphd wrote: »
    Yes, Emo ships to Sweden. Our input is 230V and the Emos support it right out of the box fortunately :) I even found a guy on a Swedish forum who had ordered one and was happy with his purchase...
  • Zeatrix
    Zeatrix Posts: 17
    edited May 2009
    dpowell wrote: »
    Sure! On the back of your AVR are the line level outputs for each speaker...
    Ok i got you this time!
    What confused me was that your talking about the LSi25 right? I was thinking of the 15 that doesn't have a built in amp.
  • Zeatrix
    Zeatrix Posts: 17
    edited May 2009
    dpowell wrote: »
    Thanks for the tips, but I actually want the new HD formats since I've started my own little Blu-Ray collcetion :)
  • dpowell
    edited May 2009
    No worries. The direction you're headed makes sense.
  • dpowell
    edited May 2009
    Zeatrix wrote: »
    I apologize. I've been misleading you this whole time.:eek: I thought for sure that both LSi's were powered towers but you are correct, the 15's are not. My bad.
  • dpowell
    edited May 2009
    .....and that's the reason you're concerned about having enough power to drive them at 4Ohms.....and to answer one of your original questions, I don't believe you can bi-amp usng the pre-outs unless they run through the separate power amp first.
  • Zeatrix
    Zeatrix Posts: 17
    edited May 2009
    dpowell wrote: »
    Well that's a given since the preouts are unamplified.
    What has me wondering is that many receivers sport the ability to bi-amp with the back surround speaker outputs but none clarify if it's also possible, or impossible for that matter, to do it with the back surround preouts.
  • dpowell
    edited May 2009
    Couldn't tell you on that one. I've never heard of bi-amping using the back surround outputs.
  • apphd
    apphd Posts: 1,514
    edited May 2009
    Zeatrix wrote: »
    Can't tell you about the Sony's you are looking at, I use a Yamaha 663 and if the Bi-amp mode is selected the front sp. signal is also directed to the rear surround pre-outs, as well as the rear surround speaker terminals. I think this could vary greatly by manufacture and model so you should read over the manuals for the AVRs you are considering.
    Somebody with more experience should confirm this, (I've never been interested in bi-amping) or download a manual for the amp you are looking at it should be there. But I'm pretty sure you can use a Y splitter on your front L-R pre-outs to bi-amp your front speakers if you are using externals. i.e. split the front R signal and connect the two cables to 2 channels of the amp. The same for the L, so you are using 4 ch. of a multi ch amp, all ch. of 2 stereo amps, or 4 mono blocks what ever way you decide to go with your amp selection.
  • Zeatrix
    Zeatrix Posts: 17
    edited May 2009
    Thanks for your response apphd. I've had a thorough look at the manuals for the amps I'm referring to and they clearly state you can use the rear surround speaker terminals but doesn't clearly state that you can or can not do the same with the preouts.
    The Yamaha being able to do just this makes it likelier that the Sony can too. But of course I'll have to check it out. I'm leaning towards not bi-amping anyways but it would be cool to have the possibility of doing it in the future.
  • jimmydep
    jimmydep Posts: 1,305
    edited May 2009
    Zeatrix, I have a Yamaha rx-v665 receiver I'm using as a preamp for an Emotiva XPA-5 powering LSI-15 fronts, LSIC center and LSIF/X rears.
    This is a similar setup to what your thinking about. I haven't tried BI-amping the LSI-15's yet but The difference between powering the speakers with the receiver or the amplifier is night and day. The LSI's came alive with the Emotiva, with an increase in bass, a significant widening of the sounstage and vocals that are powerfull and clean.
    IMHO I would let the Emotiva power all the speakers and not power the LSIF/x's from the receiver since the FX's need alot of power to reach thier full potential.
  • apphd
    apphd Posts: 1,514
    edited May 2009
    Zeatrix wrote: »
    I think this is saying "yes" to your question. From the STR-DA3400ES manual:
    2nd from the last in the "NOTES" section....."Signals output from the PRE OUT jacks are......
  • Zeatrix
    Zeatrix Posts: 17
    edited May 2009
    apphd wrote: »
    Thanks apphd. I had actually read that note (but in the Swedish manual) and I thought it was kind of none saying but if you feel that is a definite yes to my question I'm willing to trust you :)
  • Zeatrix
    Zeatrix Posts: 17
    edited May 2009
    jimmydep wrote: »
    Cheers Jimmy, exactly the kind of feedback I was looking for.
    Unfortunately I might have to pass on the FX's since my fianc
  • McLoki
    McLoki Posts: 5,231
    edited May 2009
    Zeatrix wrote: »
  • Zeatrix
    Zeatrix Posts: 17
    edited May 2009
    McLoki wrote: »
    Have you thought about the LSi7's rather than the RTi4's?
    Michael
    My bad! I meant FXi A4 when I wrote RTi A4. I like the idea of bi-directional speakers and the A4 is considerably smaller than the LSiFX.
    I have thought about bookshelf speakers but my problem is that my living room is such that I have to have the couch up against the wall and I wouldn't like the look of having two bookshelf speakers facing each other up against the wall.
    My fianc
  • dpowell
    edited May 2009
    Keep up the good fight! :D
