HELP PLEASE - Boat Tower Speaker Wiring
rsharp2000
I am wiring 4 MM651UM speakers on my boat tower and powering them via a Clarion 480XM 4-channel amplifier.
I have outlined the 4 options I see for configuring these components in the pic below and thought option #4 serial/parallel config would be best since:
1) Stereo imaging not really an issue for tower speakers.
2) only requires a 2 wire harness from tower to amp.
3) only requires 1 bridged channel (via bridging channels 3 & 4) & leaves channels 1 & 2 open for current bow speakers.
4) this config would also produce most available volume/power to speakers.
BUT when I power up this system the output volume of these 4 speakers is barely heard - NOT what I was expecting at all! I have 2 Polk MM650 speakers in the bow individually connected to channels 1 & 2 in standard stereo mode and these can be heard just fine. I obviously have got something wrong w/ the series/parallel config or my thinking for Option #4 outputs but can't figure out what !!??
I wired the 4 speakers in series then parallel and have the resultant single + wire connected to ch3+ on the amp and the - wire connected to ch4-. I have the amp channel 3/4 mode set in mono (if I switch to stereo I get nothing at all) and all filters off. Gain was left midway just like channels 1/2 for bow speakers. I could easily go to 8 wire harness & just hook up all 4 tower speakers in straight-forward stereo mode and move bow speakers to unused deck speaker outputs (Clarion CMD 04 head unit) - but really thought this parallel/serial config would be best trick way to maximize this setup.
Thanks in advance for ANY/ALL help GREATLY appreciated to resolve this for me!
Post edited by rsharp2000 on
Make sure that the connections between the speakers in series is Positive to Negative.
... here is a better drawing ... I have checked that series connections are positive to negative ... am guessing amp may not be set correctly ... should amp be set to mono for channels 3/4 if I am trying to run the series/parallel off bridged 3/4 channel? or is that too much to expect from the one channel?
... or am I better off just using the 480 amp to power the tower? bridge amp and run two 651's in series? this gives 230W RMS @ 4 ohms, .5% THD - which would be 115W/spkr but will this be okay at higher volumes?
... or can I get adequate clean power to them by wiring two 651's in parallel and running each pair off 2 separate channels? = 115W @ 2 ohms, .2% THD - but this is only 57.5W per speaker - is that too low? -
I'd go with #1. The rest will only yield about 57.5 watts/speaker.
i concur
... wouldn't option #2 (speaker pairs in series to 2 bridged channels - turn 4-channel amp into 2-channel bridged amp) provide 115W/speaker @ 4ohms each?
... was just worried whether .5% THD w/ this option (vs .05% or .2% of other options) could be an issue at high volumes - and if this config might be more likely to blow these speakers - since these are tower speakers and will be loud most of the time.
Thanks guys! -
sorry. 1&2 should be the same. The amp would see the 8ohm load as 4 ohms/ch so it should be 80+80=160 into and 8 ohm load(two 4 ohm loads in series splitting 160 watts between them, so 80 watts/load"speaker").
