Speakers stands?
Dunham_3654
Will the omni mount Gemini2 stands work with the FXi A6s? Any help would be great
Panasonic TH50PZ85U
Omnimount Lowprofile Tilt
Sony Playstation 3
Denon AVR-788
Polk RTi A9s
(FXi A6s and CSI A6 coming soon, trying to figure out the sub)
Sony Playstation 3
Denon AVR-788
Polk RTi A9s
Post edited by Dunham_3654 on
bump, any help??Panasonic TH50PZ85U
Sony Playstation 3
Denon AVR-788
Polk RTi A9s
(FXi A6s and CSI A6 coming soon, trying to figure out the sub) -
I don't think I would go with them. The top plate is only 4"x4" the FXi specs say they are 13.5" x 8.5". I don't think I would like that much hanging over. I guess they would work, just I wouldn't use them.
dun, try making your own. i bought 12' of 1x12x12 poplar or you can use any wood. cut up 6 pieces to 12x12 and the remaining gets ripped to 4x36 do some stain or clear and put it together. if you want pics of mine let me knowSamsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
Yeah man post some pictures of the stand you madePanasonic TH50PZ85U
Sony Playstation 3
Denon AVR-788
Polk RTi A9s
Don't forget to put a couple bags of sand in the stands for stability.
Dunham_3654 wrote: »Yeah man post some pictures of the stand you made
there was a thread of pics recently but here are smore. plus i am currently adding more trim to the stands to get a two tone look
Samsung pn64f8500
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
made them from a 1 x 12 x 12 from home cheapo. $7 a foot plus the silver feet came to about $100 for 2. i just stained em cherry and clear coated
more pics of the room too
Samsung pn64f8500
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
President of Club Polk -
hey sandworms, those look great !! I tried starting a thread on the same thing, before I saw this, but stands that will hold 2 fxi a6's each. I know it sounds crazy, but with my room and wall configuration, it's my best option. Plan on using pollished stainless with a solid base, beefy enough to stop a truck. Have an uncle who ownes a macheine shop and can fabricate anything. Still on the drawing board, but will post pics when done...panasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one -
Dunham_3654 wrote: »Will the omni mount Gemini2 stands work with the FXi A6s? Any help would be great
God no. I got the Gem1, which is even heavier, and it doesn't work with my F/Xi3s. The base simply isn't stout enough. Fortunately, my father-in-law is a major wood working nut, so I'm going to design something and he's agreed to build it for me and make it pretty. Now I just need to come up with a design....
Fortunately, I also have some LS/FXs, and I can modify the Gems to work with those by bolting into the bottom of the speaker. Other than that, I'd recommend staying away from those.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
get the pics up when done SJSamsung pn64f8500
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
Samsung pn64f8500
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
it all sounded good on the drawing board, but other folks here advised there might be phase issues. I gave up- back to the drawing board- your stands look awesome- good work
jrpanasonic th-50pz85u
emotiva xpa-3
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
harmony one -
Nice Job, Sand...
also glad to see someone else on this board is from RochesterLR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability. -
hey xand, great to see another upstater, you know i'm my worst critic so when i look at my stands i see all the flaws. but, not to bad for a rookie. and they do the job at the height i needed. i'm wondering if i should fill the bottom part with shot?Samsung pn64f8500
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
Not sure that'd be really necessary given those stands - what you've done is considerably more stable than most of the single post stands out there.
Nonetheless: try pushing side to side back to front. If they feel wobbly, go for it.
Unless your speakers are in the path of dashing dogs, irate children or visiting drunks - they might be fine as is - they look more stable than nearly all the stuff out on the market.LR Setup:
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
