Musical Fidelity Titan
madmax
http://www.musicalfidelity.com/products/titan/index.html
There is a review of this awesome piece of awesomeness in the latest Stereophile magazine. Looks like a pretty cool amp!
madmax
madmax
Vinyl, the final frontier...
Post edited by madmax on
It's a beast!Political Correctness'.........defined
President of Club Polk -
This has got to be an SS amp.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
The picture on MF's web page is much more flattering than the one in Stereophile."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
It's a beast!
Looks like the Beast Master to me.
Mikey likes it so it must be good. It would be interesting to hear this with the Maxx 3's at live performace levels.
Arthur SchopenhauerAll truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident. -
Only 150lbs Mother of a amp.engtaz
Actually, it is a 3 piece beast. The power supply is 150lbs and each channel is an additional 100 pounds. That is a 350lb amp! Shipping charges alone are probably as much as a standard amplifier costs. What I liked (written in stereophile) was that they say the sound is still very nice at low levels.
madmax
Its a two chassis design; Power Supply @ 150 lbs and the Amplifier @ 99 lbs. The Amplifier chassis includes both channels. The Power Supply module has two 3kVA toroidal transformers; one for each channel!!
What would this cost in usd?
$30,000 or was it 40.Political Correctness'.........defined
Looks like a nice little amp.Its a two chassis design; Power Supply @ 150 lbs and the Amplifier @ 99 lbs. The Amplifier chassis includes both channels. The Power Supply module has two 3kVA toroidal transformers; one for each channel!!Testing
Testing
Testing -
$30,000.00. I read the review in Stereophile this morning. Sounds like a lotta amp and when they compared it to other amps like Bolder it actually was cheaper per watt as a comparison.
I like the look of it. I think it has a companion Pre also.
ScottI like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
I'd still like to not only hear it..........but own it. For musical purposes of course. I could only imagine the sound stage....~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Damn...
I'd like to use it for arc welding purposes.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Throw a couple of blue meters on it & it might give Mac a run for it's money. It does seem like one serious amp though.
Another salient point by Keiko... I think I would give the upper hand to my old hitachi boom box in a side by side test against this amp. It will blow the doors off that beast.:p
............at least when it came time to move it. I cannot wait to get my ears on it!
I wonder if it is ICE powered...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
That would be a definate NO.It's about as different designwise as you could get with SS vs ICE.nooshinjohn wrote: »
I wonder if it is ICE powered...Testing
Testing
Testing -
Looks like a real powerhouse.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
http://www.mcintoshlabs.com/products/mcintosh-mc2kw-2000-watt-reference-power-amplifier.asppearsall001 wrote: »Throw a couple of blue meters on it & it might give Mac a run for it's money. It does seem like one serious amp though.
Mac has twice as much power at 8ohms."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I'd rather have the MF.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Unless I needed a stupid amount of watts, I wouldn't want either."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Yeah, but look at the 4 and 2 ohm ratings. The MF has 3800 watts at 2 ohms. Of course only the first few watts are all that matter anyway.Vinyl, the final frontier...
Hmmm....it's interesting that it stays at 2000wpc at 8,4 or 2 ohms. I don't believe I've seen that spec before.Political Correctness'.........defined
Likely something to do with their using an autoformer at the output.Hmmm....it's interesting that it stays at 2000wpc at 8,4 or 2 ohms. I don't believe I've seen that spec before.Testing
Testing
Testing -
how much better will Bose am-5's sound with that kind of power... I bet EXPLOSIVE would be a gross understatement...:DThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Yeppers.Likely something to do with their using an autoformer at the output.
The 7270 I have here is rated at 270wpc at 8, 4, 2, and 1ohm due to it's autoformers. Many also believe Mac's sound warm or tube like due to having autoformers. It's possible since their HT amps do not have autoformers and are more forward sounding. I've never heard a pair(that I know of), but aren't OTL amps more forward or transparent compared to a traditional tube amp?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Whoa! Now that is a statement amp!
I'm wondering what speakers would be the best with that amp. Certainly my Duo's at 104db sensitivity would be out...
MillerLiteScott wrote: »$30,000.00. I read the review in Stereophile this morning. Sounds like a lotta amp and when they compared it to other amps like Bolder it actually was cheaper per watt as a comparison.
Scott
I have to correct myself. They compared it to a Luxman M800A Stereo amplifier. "Considering that, for less than twice the Luxman's price, the Titan delivers well in excess of 16 times as much power into 8 and 4 ohms, it should be considered a power bargain!"
Me, at less than the cost of the Titan I will stick with my '05 F150.I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
