Is there a serial number/model number database?
StantonZ
StantonZ Posts: 452
edited May 2009 in Vintage Speakers
I'm trying to figure out if I have 10A's or 10B's. There's no external fuse on the back and the tweeters are all black. I know the tweeters are different from my 4's, but I wish I knew if they were SL1000, 2000, etc.
(2) Polk RC80i (Top Middle)
Polk CS300 center channel
Post edited by StantonZ on
    Toolfan66 Posts: 18,062
    edited May 2009
    Here are some pics.
    The first pic is 10A's the second is 10B's
    Maybe this will help you out.
    F1nut Posts: 51,772
    edited May 2009
    No.
    Post a pic to help us help you.
  • george daniel
    george daniel Posts: 12,096
    edited May 2009
    Can't you pull the tweeter and look at the back ?
  • StantonZ
    StantonZ Posts: 452
    edited May 2009
    Well, the (tweeters) are like NEITHER picture (although your pictures look the same): the coils go more horizontal, not angled down. I don't want to pull the tweeter; with my luck it will slip out of my hand and there goes the dome. I must have a 10B with some later model tweeter, although I remember replacing one of them years ago (like the late 80's) and all four match.
    F1nut Posts: 51,772
    edited May 2009
    So, post a picture.
  • StantonZ
    StantonZ Posts: 452
    edited May 2009
    Didn't know it was that easy.
    F1nut Posts: 51,772
    edited May 2009
    That's an SL2000. You might consider upgrading to the RD0-194-1 silk dome replacement tweeters from Polk. They are sweeter and much smoother.
    Oh yeah, those are 10B's.
  • StantonZ
    StantonZ Posts: 452
    edited May 2009
    Thanks!
  • Hillbilly61
    Hillbilly61 Posts: 702
    edited May 2009
    StantonZ wrote: »
    That is a cool question. Most SNs follow a sequence of some sort. If enough original owners post when bought and the SNs then a database of ranges (if Polk is not talking) can be framed.
  • StantonZ
    StantonZ Posts: 452
    edited May 2009
    Theoretically, they should have a database of every speaker (serial number) that went out along with what kind of tweeters, drivers, etc. were in them. But I have no idea how sophisticated their shipping & tracking was back when
    edited May 2009
    It would be intresting to know what the quanity was of each pair that was manufactured of the SDA's
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2009
    It doesn't exist and wouldn't be available if it was....enjoy your loudspeakers.
  • nadams
    nadams Posts: 5,877
    edited May 2009
    apparently Polk wasn't that worried about keeping track of their loudspeakers. It wouldn't have been that hard, even back then, to keep track of the serials.
    Ludicrous gibs!
