Whats all this talk about TL upgrades????
george daniel
george daniel Posts: 12,096
edited May 2009 in Vintage Speakers
I am aware of the SDA 2B and CRS TL upgrades, but I thought I read/heard somewhere on this forum about TL upgrades for other SDA series speakers.Did I just totally miss something?Could someone "in the know" please confirm or deny this,please. I am about to perform one of my last two upgrades to my 1C's (RDO 194 replacement)and if this is something that can be done to enhance other SDA's (crossover mod) to allow the use of the RDO198,,,then please educate me. Thanks in advance.
Post edited by george daniel on
  • george daniel
    edited May 2009
    or,, should I be ordering the RDO 198's ;)
    Come on,,, you know :cool:
  • ben62670
    ben62670 Posts: 15,969
    edited May 2009
    The 1.2 to 1.2TL mod is the only one I have going now. Another Polkie did his upgrade on 1C's, and I don't doubt the outcome, but it can not be a proven proper upgrade without running some serious test. The Problem with the 1C's is there was never a 2500-3000 tweeter option to mimic the XO's. What I am doing is not reengineering the XO's but copying a proven design. We'll talk soon George.
    Ben
    Ben
    F1nut Posts: 52,005
    edited May 2009
    Agreed.
  • george daniel
    edited May 2009
    rdo 194'S ordered,, thanks guys--george :)
  • Face
    Face Posts: 14,340
    edited May 2009
    It doesn't appear that difficult. It's possible that all one would have to do is add the 2.7ohm/5.8uf contour circuit to the HF section, then adjust the values of the resistors before the tweeters. I may look into this when I'm done with my two current projects.
    I'd also like to look into adding a BSC(baffle step compensation) circuit, that would allow us to move them further away from the wall without a loss in bass response only at the expense of losing a few dB of efficiency.
  • ben62670
    edited May 2009
    Face wrote: »
    Yep. The 1C's run one tweeter at full range(the top), and the bottom one is rolled off. The two 7.5's need to be reduced by about 2ohms to keep the impeadance correct.
    Ben
