SDA 1A TL upgrade
nduitch
nduitch Posts: 316
edited May 2009 in DIY, Mods & Tweaks
I'm getting ready to upgrade the cross overs on my 1A's and have been reading about this TL conversion, why do you prefer the rdo 198 to the 194? Also has anyone ever done this on this model and what exactly is involved?
Post edited by nduitch on
  • Bigbang
    Bigbang Posts: 233
    edited May 2009
    I'm in the same pinch as well. There is some more serious work that needs to be done to the crossover to make the 198's work well. I'd like to kow the diffference between the 194's and the 198's. I assume the 194's is a swap out upgrade but Ben has been working on the 198 upgrade and has it figured out. I'd love to hear feedback from others as well...
    d
    I like to listen, tinker, listen and repeat.
  • fbm211
    fbm211 Posts: 1,488
    edited May 2009
    Yes me too.I have the 5.8uf sonicaps and would like to know where exactly I insert the leads.What holes?A pic would be cool...And how do the 198s sound compared to the 194?
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • Face
    Face Posts: 14,340
    edited May 2009
    fbm211 wrote: »
    http://www.polkaudio.com/forums/attachment.php?attachmentid=26710&d=1186358580
  • Conradicles
    Conradicles Posts: 6,391
    edited May 2009
    If these cats say the TL upgrade is worth it, do it. They have been there done that.
  • fbm211
    fbm211 Posts: 1,488
    edited May 2009
    Face ,I have the blade /blade version.Does that matter.I remember reading a post by F1nut that you have to use the H hole or some such
  • Face
    Face Posts: 14,340
    edited May 2009
    I was under the impression that the HF circuit of the 2A(b/b) and 2B(P/B) were identical and that the mod should work for both. Just bypass the 2.7ohm resistor with your 5.8uf cap and you should be golden.
  • nduitch
    nduitch Posts: 316
    edited May 2009
    Face wrote: »
    Aren't we talking about 1A's?
  • Face
    Face Posts: 14,340
    edited May 2009
    Sorry, I was answering fbm211's question.
    There is no official TL mod for the 1A.
  • Disc Jockey
    Disc Jockey Posts: 1,013
    edited May 2009
    Face wrote: »
    The 2A and 2B are slightly different with the 2A having an extra 2.7 ohm in line with the inductor. The 2B(b/b) and the 2B(p/b) use the exact same components.
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
  • fbm211
    fbm211 Posts: 1,488
    edited May 2009
    Quoting F1nut in another thread:
    To do the "TL" upgrade do as above adding a 5.8uF Sonicap (custom value) in the C5 position, running the one lead into the H hole and the other lead into the C5 hole closest to R2.
    EDIT: One thing to note is that on my crossovers, the H hole was covered up by the hot glue from the small corner inductor. Carefully pry the glue off to expose the H hole.
  • nspindel
    nspindel Posts: 5,343
    edited May 2009
    fbm211 wrote: »
    I believe you're quoting me there, quoting F1 :p
    Have a look here for my 2B upgrade:
    http://www.polkaudio.com/forums/showthread.php?t=62106
    F1nut Posts: 52,055
    edited May 2009
    Guys, I had to wire it up that way to complete the circuit. I would advise you check your own crossover board to see what needs to be connected where.
