Lsi9s How many watts? Bookshelf system?
NeedingInfo
Hi,
I just replaced 2 of my 6 lsi9s with lsi15s, so I now have 2 spares that I want to make use of. I would like to use them in my office at work if possible, as part of a bookshelf system on my credenza.
I currently have an Onkyo bookshelf system there that is rated at 4 ohms, but the output at 4 ohms is only 20 watts. Does anyone think that will work?
Again, I am not looking to blast them, but I don't want to have to be 4 inches from the speakers to hear anything either...
Post edited by NeedingInfo on
You should look for something around 200wpc at 8ohm to make them sing as they should. Carvers are a great choice and can be had for reasonable prices. I have heard of others using tube amps to great results as wellNeedingInfo wrote: »Hi,
Again, I am not looking to blast them, but I don't want to have to be 4 inches from the speakers to hear anything either...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
You'll be ok for low level listening."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
+1. They obviously won't sound their best, but you already know that. Pretty good little office rig though.Things work out best for those who make the best of the way things work out.-John Wooden -
What Onkyo you have that is rated 4ohms and only getting 20w?Life without music would♭
A CR 325 combo amp \ CD system...
Yeah as stated prev you should be good at low levels. I wouldnt get to crazy as you run the risk of damage to avr/speakers since its only rated 20wpc @ 4ohms
PaulyLife without music would♭ -
This may be the time to upgrade to the NAD C715. It would be a shame to let such nice speakers go to waste...
It's fair to say you'll need a more powerful amplifier. BUT, you do NOT need 200 wpc, what you do need is QUALITY power. I've said this many times before, I have a 38wpc int. tube amp that made my LSi9's sing far better than a 150wpc class d amp, or a typical 120wpc solid state amp. Now, let's say you find a high quality SS amp at 70wpc, I'll bet they'll do just fine.
Used Amp recommendations:
Jolida 1501
Cambridge A640
The key will be speaker placement, as it sounds like they will be sitting on the credenza.Review Site_ (((AudioPursuit)))
Former Staff Member TONEAudio
2 Ch. System
Cable/Wires: Cardas, AudioArt, Shunyata Venom 3 -
NeedingInfo wrote: »This may be the time to upgrade to the NAD C715. It would be a shame to let such nice speakers go to waste...
Yeah i sense an upgrade soon.
The last LSi 9 rig I heard used 1000 watt Threshold Mono-blocks with an ARC tubed pre, it did sound rather awesome.
RT1 -
reeltrouble1 wrote: »The last LSi 9 rig I heard used 1000 watt Threshold Mono-blocks with an ARC tubed pre, it did sound rather awesome.
RT1
yeah, I'd imagine thats more than a decent way to get the most out of the 9'sLiving Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
Get two Outlaw Monoblocs...HT: Ninja Master LSi9s, Ninja Master LSiC, Slightly Modded LSiFXs, Modded LSi7s, Outlaw LFM-1 EX and Polk PSW125
Outlaw 970 Preamp, Outlaw 7700 Amp, Velodyne SMS-1, Oppo BDP-83,
2 APC H-15s and a Panamax 5400 for good measure
Stereo: DIY Alix Music Server, DODD Audio Battery Tube Buffer, Modded DAC-60 and MF V-Link (for now), DIY Silver ICs, Battery Powered Class D SDS-254 Amp, and GR-Research N2X Speakers -
RT1
I have to agree, that system sounded really, really good!DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
The speakers that came with your Onkyo system were 4 Ohm also, like the LSi9's, and have even lower sensitivity (down around 83-85dB, I think). So your Polks will play louder. And considering your stated use, I think you'll be in good shape, volume-wise. Just don't try to push'em too hard!:) Besides, even 20W will get you around 100dB of peak output at one meter. I'd think that would be way plenty in most office environments. But now, for office parties all bets are off!THE MAN-CAVE 5.1 CHANNEL A/V RIG
Sony KDS-60A3000
a/d/s/ HT-400LCR (3)
a/d/s/ HT-300 (2)
Velodyne DLS-4000R (2)
Pioneer Elite VSX-55TXi
Pioneer Elite DV-47Ai
Sony BDP-S300
Sony SLV-779HF
DirecTV HD sat. receiver
MAN-CAVE 2-CHANNEL RIG (shares sources with a/v system)
Adcom GFA-5500
Bose 901 Series VI
NAD C-165BEE
Slim Devices Squeezebox Classic
TEAC CD-RW890
Technics SL-BD20D w/ Audio-Technica P34
Akai HX-A3X
