Lsi9s How many watts? Bookshelf system?
NeedingInfo
NeedingInfo Posts: 9
edited May 2009 in 2 Channel Audio
Hi,
I just replaced 2 of my 6 lsi9s with lsi15s, so I now have 2 spares that I want to make use of. I would like to use them in my office at work if possible, as part of a bookshelf system on my credenza.
I currently have an Onkyo bookshelf system there that is rated at 4 ohms, but the output at 4 ohms is only 20 watts. Does anyone think that will work?
Again, I am not looking to blast them, but I don't want to have to be 4 inches from the speakers to hear anything either...
Post edited by NeedingInfo on
    nooshinjohn Posts: 25,939
    edited May 2009
    Hi,
    You should look for something around 200wpc at 8ohm to make them sing as they should. Carvers are a great choice and can be had for reasonable prices. I have heard of others using tube amps to great results as well
  • Face
    Face Posts: 14,340
    edited May 2009
    You'll be ok for low level listening.
  • PSOVLSK
    PSOVLSK Posts: 5,396
    edited May 2009
    Face wrote: »
    +1. They obviously won't sound their best, but you already know that. Pretty good little office rig though.
  • Pauly
    Pauly Posts: 4,519
    edited May 2009
    What Onkyo you have that is rated 4ohms and only getting 20w?
    Life without music would
  • NeedingInfo
    edited May 2009
    A CR 325 combo amp \ CD system...
  • Pauly
    Pauly Posts: 4,519
    edited May 2009
    Yeah as stated prev you should be good at low levels. I wouldnt get to crazy as you run the risk of damage to avr/speakers since its only rated 20wpc @ 4ohms
    Pauly
  • NeedingInfo
    edited May 2009
    This may be the time to upgrade to the NAD C715. It would be a shame to let such nice speakers go to waste...
  • markmarc
    markmarc Posts: 2,309
    edited May 2009
    It's fair to say you'll need a more powerful amplifier. BUT, you do NOT need 200 wpc, what you do need is QUALITY power. I've said this many times before, I have a 38wpc int. tube amp that made my LSi9's sing far better than a 150wpc class d amp, or a typical 120wpc solid state amp. Now, let's say you find a high quality SS amp at 70wpc, I'll bet they'll do just fine.
    Used Amp recommendations:
    Jolida 1501
    Cambridge A640
    The key will be speaker placement, as it sounds like they will be sitting on the credenza.
    Former Staff Member TONEAudio
    2 Ch. System
  • Pauly
    Pauly Posts: 4,519
    edited May 2009
    Yeah i sense an upgrade soon. :)
    Pauly
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2009
    The last LSi 9 rig I heard used 1000 watt Threshold Mono-blocks with an ARC tubed pre, it did sound rather awesome.
    RT1
  • ohskigod
    ohskigod Posts: 6,505
    edited May 2009
    RT1
    yeah, I'd imagine thats more than a decent way to get the most out of the 9's
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • praedet
    praedet Posts: 314
    edited May 2009
    Get two Outlaw Monoblocs...
    HT: Ninja Master LSi9s, Ninja Master LSiC, Slightly Modded LSiFXs, Modded LSi7s, Outlaw LFM-1 EX and Polk PSW125
    Outlaw 970 Preamp, Outlaw 7700 Amp, Velodyne SMS-1, Oppo BDP-83,
    2 APC H-15s and a Panamax 5400 for good measure ;)
    Stereo: DIY Alix Music Server, DODD Audio Battery Tube Buffer, Modded DAC-60 and MF V-Link (for now), DIY Silver ICs, Battery Powered Class D SDS-254 Amp, and GR-Research N2X Speakers
  • dkg999
    dkg999 Posts: 5,647
    edited May 2009
    RT1
    I have to agree, that system sounded really, really good!
    DKG999
  • dougy
    dougy Posts: 182
    edited May 2009
    The speakers that came with your Onkyo system were 4 Ohm also, like the LSi9's, and have even lower sensitivity (down around 83-85dB, I think). So your Polks will play louder. And considering your stated use, I think you'll be in good shape, volume-wise. Just don't try to push'em too hard!:) Besides, even 20W will get you around 100dB of peak output at one meter. I'd think that would be way plenty in most office environments. But now, for office parties all bets are off!
    THE MAN-CAVE 5.1 CHANNEL A/V RIG
    Sony KDS-60A3000
    a/d/s/ HT-400LCR (3)
    a/d/s/ HT-300 (2)
    Velodyne DLS-4000R (2)
    Pioneer Elite VSX-55TXi
    Pioneer Elite DV-47Ai
    Sony BDP-S300
    Sony SLV-779HF
    DirecTV HD sat. receiver
    MAN-CAVE 2-CHANNEL RIG (shares sources with a/v system)
    Adcom GFA-5500
    Bose 901 Series VI
    NAD C-165BEE
    Slim Devices Squeezebox Classic
    TEAC CD-RW890
    Technics SL-BD20D w/ Audio-Technica P34
    Akai HX-A3X
