RTi10 Mod #2...
RedLetterDay
RedLetterDay Posts: 7
edited May 2009 in DIY, Mods & Tweaks
So a while ago I posted a thread where I showed how I painted the front of my black RTi10s because I thought the silver looked kind of cheap. It yielded satisfactory results but I still thought the speakers looked a little off, especially with the old grills. Additionally I decided that I no longer liked the black color of the speakers, the only reason I had actually chosen them over the cherry color is because I was able to get these for significantly less, and being in college, money is unfortunately never easy to come by. :p
Anyways, I decided to do a complete overhaul. I took the entire speakers apart, first sanding down the fronts to completely flat (I think I ended up taking about 1/2 inch total off) to get rid of all that cheap material on the front. Maybe someone can do a quick measurement to figure out exactly how I much I took off -- my RTi10s are now 14 and 1/4" deep.
Then I sanded down the exterior and stained the wood with 1 coat of Minwax Red Oak and applied 2 coats of polyurethane. Also I made some new grills using 3/8x3/8 strips of bass wood, a hand miter saw, some glue, and staples for the grill cloth. Who knew that my freshman year 3D design class would have been useful down the road, hah.
So here's how they came out, the second speaker is still in the works but its almost done and theoretically should be exactly the same as this one.
Post edited by RedLetterDay on
  • zingo
    zingo Posts: 11,258
    edited May 2009
    That has a pretty cool 70s look. Great job!
  • Face
    Face Posts: 14,340
    edited May 2009
    Looks great, but where are the grill less pics?
  • ben62670
    ben62670 Posts: 15,969
    edited May 2009
    Please repost the pics from before. They disappeared from your other thread.
    Ben
  • RedLetterDay
    edited May 2009
    Hah, I'll have to take some more pictures later.
    Re-uploaded them to my server -- should be working now. I'll just post them here so people don't have to go to the other thread. Here's what they looked like before:
    Toolfan66 Posts: 18,127
    edited May 2009
    I would keep the feet on them or at least spike them. Looks good, would also like to see before and after pics.
  • ben62670
    edited May 2009
    I like the new look. The black has done well to highlight the grain.
    Ben
  • danz1906
    danz1906 Posts: 5,144
    edited May 2009
    Congrats, the speakers look great!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
    VR3 Posts: 29,502
    edited May 2009
    You need to reattach the power port base to the rear port as it was designed for it to be in place.
  • ViperZ
    ViperZ Posts: 2,046
    edited May 2009
    Red oak color looks nice. I am picking the color for my RT1000p, since I just finished veneering those :cool:
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • RedLetterDay
    edited May 2009
    Eh... I did a test a while ago with it on one speaker and off the other and switched the balance back and forth, I couldn't hear any noticeable difference. That and the fact that it looks horribly ugly made me decide to just take them off.
    Cool deal, I just did one coat on the speaker above but I'm thinking on the second speaker I might try 2 and see how much of a difference it makes. :)
