power amp or pre amp difference is...???
shondoman
im looking to upgrade and use power amps for my home theater but whats the differance with a power amp and a pre amp would a pre -work to power speakers or is for somthinfg else??
Post edited by shondoman on
What receiver are you using now? If it has ' Pre Outs ' you can add an amp to it. A Pre Amp is a controller. An Amp is the power.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Assuming you arent jerking me around, a pre-amp (before the amplifier) provides, and possibly conditions, the source (CD, tuner, turntable, etc.) electrical signal (the music), to the (power) amplifier which increases (amplifies) the electrical signal, and sends the electrical signal to the speakers, which, depending on the size of the signal, will then vibrate in rhythm to the signal, and make some type of sound, depending on the input signal.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Well, to put it into simpler terms...
Pre, is a prefix meaning earlier, before or prior to, amongst numerous other definitions. Given that defintion, a pre-amp is what comes before, or prior to, the amp. Thus the term, pre-amp.;)
The pre-amp is just the controller. You hook up your CD player, turntable, radio tuner etc... to it, and allows you to switch between your various sources. It also controls your volume level, tone controls(bass,treble) and numerous other features which vary from model to model.
The pre-amp is then followed by the power amp, which is what provides the amplified current to your speakers. The power amp's sole function is providing the amplified current.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Many thanks to all of you. I am moving from a receiver system to a pre, power, tuner system for my "new" 2As.
This is a great place to keep learning. -
^^^^^^^^^ whats up here. 2009 thread. So whats your intent ?Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
josephtenzin wrote: »Many thanks to all of you. I am moving from a receiver system to a pre, power, tuner system for my "new" 2As.
Welcome to Club Polk Joseph, You will enjoy your system for years to come. Get as much power as you can afford so that your current speakers and any others you get in the future will have all they need to sound their best.
Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
http://www.chuckhawks.com/stereo_pre-amp_basics.htm
Here you go Joe this will clarify it for you have fun, and welcome to the club.Home Theater
More informationon what your doing would be cool. We kinda like talking about amps preamps n speakers around here
youll love seperates Randy-Maine
by David WMG
