power amp or pre amp difference is...???
shondoman
shondoman Posts: 27
edited May 2009 in Electronics
im looking to upgrade and use power amps for my home theater but whats the differance with a power amp and a pre amp would a pre -work to power speakers or is for somthinfg else??
Post edited by shondoman on
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited May 2009
    What receiver are you using now? If it has ' Pre Outs ' you can add an amp to it. A Pre Amp is a controller. An Amp is the power.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • BlueFox
    BlueFox Posts: 15,251
    edited May 2009
    shondoman wrote: »
    Assuming you aren’t jerking me around, a pre-amp (before the amplifier) provides, and possibly conditions, the source (CD, tuner, turntable, etc.) electrical signal (the music), to the (power) amplifier which increases (amplifies) the electrical signal, and sends the electrical signal to the speakers, which, depending on the size of the signal, will then vibrate in rhythm to the signal, and make some type of sound, depending on the input signal.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited May 2009
    Well, to put it into simpler terms...
    Pre, is a prefix meaning earlier, before or prior to, amongst numerous other definitions. Given that defintion, a pre-amp is what comes before, or prior to, the amp. Thus the term, pre-amp.;)
    The pre-amp is just the controller. You hook up your CD player, turntable, radio tuner etc... to it, and allows you to switch between your various sources. It also controls your volume level, tone controls(bass,treble) and numerous other features which vary from model to model.
    The pre-amp is then followed by the power amp, which is what provides the amplified current to your speakers. The power amp's sole function is providing the amplified current.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Many thanks to all of you. I am moving from a receiver system to a pre, power, tuner system for my "new" 2As.
    This is a great place to keep learning.
  • boston1450
    boston1450 Posts: 7,758
    edited January 2015
    ^^^^^^^^^ whats up here. 2009 thread. So whats your intent ?
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • cfrizz
    cfrizz Posts: 13,415
    Welcome to Club Polk Joseph, You will enjoy your system for years to come. Get as much power as you can afford so that your current speakers and any others you get in the future will have all they need to sound their best.
    gudnoyez Posts: 8,161
    http://www.chuckhawks.com/stereo_pre-amp_basics.htm
    Here you go Joe this will clarify it for you have fun, and welcome to the club.
  • boston1450
    More informationon what your doing would be cool. We kinda like talking about amps preamps n speakers around here :smile: youll love seperates
    Randy-Maine
    by David WMG
