Need some advice on an amp!!!
Fl plague
Fl plague Posts: 8
edited September 2009 in Car Subwoofer Talk
I've got 2 pioneer premier subs 12in. Their about 9 years old, have a 200rms and 800 peak wattage. And am looking for a good amp to push 'em. I'd like to spend under $300 but am willing to go i little higher if its a really good deal. i was looking at the Pioneer PRS-D2200T 2-Channel Class FD Amplifier 1200W. wanted to get some input on this amp. Thanks for the help.
Post edited by Fl plague on
  • cadenceclipse
    cadenceclipse Posts: 459
    edited May 2009
    i'd recommend monoblock for subs. that amps gotta be over 3oo anyway... just like all my other amp recommendations for lots of juice and quality w/ small pricetag(and footprint) ahhh.. cadence ia7+HC or 9. check out specs at cadencesound.com. jason at powermaxelectronics will hook u up. under 300 for ia7 barely over for ia9. theres tons of amps out there, and some qaulity,polk, etc. not like this deal...
    Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
  • Fl plague
    Fl plague Posts: 8
    edited May 2009
    I got the speakers for free and just need a good amp. I'm not sure what the #'s you put in the msg. mean but am interested to learn more. I'm a big ebay shopper and can get the amp for about $260 thats shipping included.
  • Fl plague
    Fl plague Posts: 8
    edited May 2009
    Looked at the specs for the cadence speakers. (I now know what the #'s mean) and notice there mono. I have two subs is there a way to make that work?
  • cadenceclipse
    edited May 2009
    260 for what amp? what r subs impedence? 2 ohms? 4 ohms? DVC?(dual voice coil) or SVC single? if not sure, whats model #? most likely yes..
  • Fl plague
    Fl plague Posts: 8
    edited May 2009
    4 ohms, also $260 is the price for the pioneer amp.
  • ahardy17
    ahardy17 Posts: 84
    edited May 2009
    Fl plague wrote: »
    maybe you could find a Pioneer GM5400T that pushes 380 watts rms into a 2 ohm load and wire them in parellel...walmart sells those amps cheap
    In-Car:
    Head Unit: Sony MEX-1GP
    Door speakers: Infinity Kappa 680.9cs
    Rear speakers: Polk db690
    Subwoofers: Memphis Audio 15-M3124
    Amps: Pioneer GM5300T, Kenwood KAC 6020, Memphis Audio MCD1.1100
    In-Home:
    Harmon/Kardon AVR 230
    Harmon/Kardon DVD 101
    Yamaha RX-V995
    Bose 161
    Bose 901
    Polk FXi30
  • cadenceclipse
    edited May 2009
    ahardy17 wrote: »
    haha walmart amps
    u could do either ia7 or ia9. ia7 is all u really need(specially since there 9 yrs old) plus if 1 goes that amp will push 1 at 4 ohms very well(ia9 also would). and when they both go u'll still have some cash plus a sweet amp for your next 12.
  • ahardy17
    ahardy17 Posts: 84
    edited May 2009
    haha walmart amp
    yeah, a walmart amp for those walmart subs he has...the shoe fits. not saying i'd recommend a memphis audio mclass amp for something so ****...i'll save that for my M3's :cool:
    In-Car:
    In-Home:
    Yamaha RX-V995
    Bose 161
    Bose 901
    Polk FXi30
  • cadenceclipse
    edited May 2009
    haha they R premiers'. but yeah, guess they R 9 yrs old. but he DID say "good". u'd be totally right hardy except for suggesting that after my suggestion. your recommendation isn't hurting any1 by any means but u do see how i can b humored after my recommendation. bet u'd recommend mclass if u could get it for under 300 w/ 5 yr warranty:eek:..
  • ahardy17
    ahardy17 Posts: 84
    edited May 2009
    true he did say good...but to be fair my "walmart" pioneer gm5300T pushes one of my m3's alright for itself considering...just don't report me for that crime haha i have no money for the mclass amp i've been drooling over...and no car anyway lol...and if i could get that for under 300, it'd be sitting pretty on the back of my sub box already :D
    In-Car:
    In-Home:
    Yamaha RX-V995
    Bose 161
    Bose 901
    Polk FXi30
  • Fl plague
    Fl plague Posts: 8
    edited May 2009
    So what is wrong with the amp Pioneer PRS-D2200T 2-Channel Class FD Amplifier 1200W. It looks like a really good amp but I'm not sure.
  • Fl plague
    Fl plague Posts: 8
    edited May 2009
    Also would I need to buy two of those amps or just one. 1a9, a7.
  • cadenceclipse
    edited May 2009
    nothing wrong w/ prs amps or gms for that matter. i'm sure that amp wil even work well for your application. just no where near as well as cadence ia monoblock. u can buy as many as u'd like. 1 ia7 would give each sub over 400wrms, ia9 over 600. so guess technically speaking you could do 2 ia7s or 1 ia9 but 1 ia7 is all u will ever need..
  • Fl plague
    Fl plague Posts: 8
    edited May 2009
    So how would i hook up two speakers to the 1a9 amp. I believe it says its mono. Would i just put both speaker wires together instead of seperate?
  • cadenceclipse
    edited May 2009
    u know depends. owners manual or crutchfield explains but depends on if its a single terminal on box or 2 seperate terminals(1 for each sub). i believe the amp will have 4 inputs, 2 pos, 2 neg. so if 2 terminals, 1 to each. if 1 terminal, you'd put pos on 1 side(input) and neg on the other. x_ _x the amp will even say how at the inputs(bridged)
  • ahardy17
    ahardy17 Posts: 84
    edited May 2009
    what are they single voice coils? 4 ohms? wire them in parellel, i dont know anything about these cadence amps but i'm sure they can handle a 2 ohm load, right cadenceclipse?
    In-Car:
    In-Home:
    Yamaha RX-V995
    Bose 161
    Bose 901
    Polk FXi30
  • cadenceclipse
    edited May 2009
    1 ohm parallel thats what i was looking for..:D
  • ahardy17
    ahardy17 Posts: 84
    edited May 2009
    these cadence amps push 1 ohm loads? niiiceee:cool:
    In-Car:
    In-Home:
    Yamaha RX-V995
    Bose 161
    Bose 901
    Polk FXi30
  • Fl plague
    Fl plague Posts: 8
    edited May 2009
    Would the 1 ohm be a problem with what I've got? I know together they push 2 ohms
  • cadenceclipse
    edited May 2009
    no. just means going 2 ohms is extra safe and less distortion. i got a7, same amp just bout 8 yrs older. they finally just replaced it. i'm doing 2ohm also. my 4-channel a4 is also 1 ohm or 2ohms bridged stable..:cool::cool:
  • JennyStarzzzz
    JennyStarzzzz Posts: 3
    I have a 15 inch solo baric 1000 watt RMS for sale, along with it comes a 2400 watt Legacy amp to power it, Im asking 400 or best offer, The sub was 550 new and the amp was 250 let me know if youre interested.
