SDA2Bs With new caps. Awsome
fbm211
I now have new caps and resistors and my 2Bs have gone to a whole new level of SQ. Detail,and resolution are improved.Bass and soundstage were a bit laid back at first but after a few hours they are now better than before.And the highs..Wow, the highs are so clean and sharp.I must have sat and listened for 5 hours just amazed at how good they sound now.That was only the beginning though
After a few hours I couldnt take it any longer and got to hooking up the 2new pair of air matrix ICs I got on audiogon.I replaced the monster ICs I had going from the DAC to pre and pre to amps. Again I had a huge boost in SQ that surpassed my expectations.And the some...
Part 3 will be modding the amps with bypass caps in a few days.Maybe saturday morning.:D
The only thing left to do after that is to TL Em. 5.8 sonicaps are on the way as of yesterday.Ill hold of on the 198s a few weeks cause money is a little tight after all these latest upgrades....I will post pics of the 565 mods after I install the bypass caps just to make sure I get it right.(Its my first amp mod after all)
Last, a big thanks to ben for doing the rebuild.Great soldering skills and a pro looking job.They sound AWSOME. Now Im going to go listen to a few more CDs:D:D:D
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
Congrats!
What caps did you go with?
You can recoup some of your money by selling the 194's...
Just wait till you install the TL mod/198's.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Dayton 1% caps...........I dont have 194s.Just the old sl2000s. But they do sound better, sort of..SDA-2BTL with custom IC
