Polk RTA-11T Help
lvevo
lvevo Posts: 11
edited May 2009 in Vintage Speakers
Hello all,
I just got my first pair of Polk Audio speakers RTA-11T's. I have one problem though. One of the mid bass drivers on one speaker is seized and won't move at all. I took out the driver to look at it and noticed that it has the markings for a SDA driver, not RTA. Could I have mis matched drivers with my 11T's? Also Where do I search, or what key words do I type to find out how to modify speakers on this site? Thanks
Post edited by lvevo on
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2009
    Welcome to Club Polk. Contact Customer Service and they will be able to help you out getting a new driver.
    Be sure to tell them you are a CP member.
  • lvevo
    lvevo Posts: 11
    edited May 2009
    cfrizz wrote: »
    Thanks for the info on customer service.
    Do you think I have the correct drivers for these speakers?
  • Disc Jockey
    Disc Jockey Posts: 1,013
    edited May 2009
    The RTA line shared a lot of drivers with the SDA line. What is the part number on the driver?
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
  • gdb
    gdb Posts: 6,012
    edited May 2009
    I think that you'll find out that vintage Polk speakers are also sometimes "like a box of chocolates"......they used whatever was at hand occaisionally and also made substitutions mid-model on some models of the older speakers. I find this very confusing! Depending upon which MW65XX driver is bad, you might be able to buy a new replacement one directly from Polk, some models are NLA unfortunately. The bad thing is that the new one won't sound the same as the others right away,if ever. That being the case, I'd try to repair the one you have or, find a used driver in good shape. The flea market here has a Wanted section in it and you can sometimes find them on ebay. Here's a link to how a repair can be done, I've never tried it myself but I definitely will if I ever need to. Depending on which MW model you have, I might be interested in buying it from you if you decide not to repair it and go for a replacement. Link:
    http://www.audiokarma.org/forums/showthread.php?t=202963
  • lvevo
    lvevo Posts: 11
    edited May 2009
    I'll have to check when I get home from work. I think I remember the stamp being faded and looking at the other working driver for a part number.
  • lvevo
    lvevo Posts: 11
    edited May 2009
    gdb wrote: »
    I think that you'll find out that vintage Polk speakers are also sometimes "like a box of chocolates...
    lol. Hopefully i get to find out what you meaning first hand.
    gdb wrote: »
    I'll let you know what model and what's going to happen.
  • Ron Temple
    Ron Temple Posts: 3,212
    edited May 2009
    I believe the RTA 11T used the MW6510 and 11 which are used in several of the SDA models.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
    heiney9 Posts: 25,504
    edited May 2009
    The RTA 11T used the MW6510 for both drivers, they are both crossed at exactly the same point. A true D'appolitto array.
  • seeclear
    seeclear Posts: 1,244
    edited May 2009
    FYI :p
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • lvevo
    lvevo Posts: 11
    edited May 2009
    Here's the picture of the driver: MW 6510. So it belongs as others have said. Also I included a picture of the corner of that speaker, which shows the after math of the previous owners moving attempt? I'm not quite sure what to do about yet.
  • gdb
    gdb Posts: 6,012
    edited May 2009
    Ivevo, the 6510 is used in my SRS2s and so I'd definitely be interested in buying the frozen one that you have to experiment with. If you're interested in selling it for a reasonable price please let me know by PM what you'll take for it plus shipping to zip# 21771 Thanks gdb:)
  • lvevo
    lvevo Posts: 11
    edited May 2009
    gdb wrote: »
    I think I'm going to fix it, or give it a shot. I saw a pair of RTA 8T near me for $75.00 obo that I might pick up for parts. I really like my RTA 11T for the tower look and sounds good to me.
  • gdb
    gdb Posts: 6,012
    edited May 2009
    lvevo wrote: »
    No problem, I think I might have a few others that I can get a hold of.:)
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited May 2009
    I think the RTA 11T's look bad ****.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
