Another which one to get thread... onkyo 705 or 805
Polkie918
I think im gonna upgrade from my 606 and get one with preouts and a bit more power....
which one is a better buy...the 705 100 watts or the 805 130 watts...
that extra 30 watts per channel sound pretty good and the price isnt that much more,..maybe 150 or so
Fronts- RTi8
Center- CSi5
Rears- FXiA4
Sub- Velodyne 12"
Onkyo TX-SR806
Ps3
Xbox 360
65" DLP 1080P Toshiba TV
Center- CSi5
Rears- FXiA4
Sub- Velodyne 12"
Onkyo TX-SR806
Ps3
Xbox 360
Post edited by Polkie918 on
I can state from experience jumping from a Yamaha with 105 watts per channel to a Pioneer 130 watts per channel, there is a significant difference. I know this is kind of apples to oranges analogy. But I would say that when you buy a reciever that gives to 130 watts over 7 channels into 8 ohms, you get a much better product generally speaking. Well in my case I did anyway."They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
Pound for pound, dollar for dollar the 805 is perhaps the best Onkyo has made in while. There are better receivers. But you won't get the power a 50+ pound 805 with Burr Brown DACs and 60 amps of instantaneous current output. The only thing it doesn't have that the higher 875 has is the silicon optics video chip upconversion and VLSC processing for digital sound. Otherwise the amp sections are almost twins.
805 (exempting video) some of the best 'value' ever from Onkyo! And into 8 ohms it will give you at LEAST 130 watts into 5 channels...so it's honestly rated for power. It can do 7.1 as well of course.
yea I only use 5.1 how my room is setup 7.1 wouldnt really be possible...
ok so I am gonna save up for the 80x series...what about the 806?
I heard the 805 has better power but not as good video??Fronts- RTi8
Center- CSi5
Rears- FXiA4
Sub- Velodyne 12"
Onkyo TX-SR806
Ps3
Xbox 360
65" DLP 1080P Toshiba TV -
OP, as most will tell you get as much as you can within your means. If you can spring for the 876 or 906 do it.
It looks like with the speakers you have you will be happy with the upgrade in power. And since you have the upgrade bug, the pre outs will be nice when you can get an amp.Man Cave: 7.1
-PS Audio Power Plant Premier
-PS Audio Power backup
-Onkyo Pre/Pro> 2 Adcom555se bridged and bi-wired> RTi A9s
> Adcom GFA 7605> CSi A6 center, RTi A3s side rears, FXi A6s rears
>Sub = MK Audio 10'
-PS3
-Onkyo 5 disc cd player
-Directv
-Samsung 59' plasma flanked by 2 Samsung 43' plasma's -
hehehe cant afford those thats for sure....looks like i can get the 805 or if very luck the 806 on ebay for 500-550...those are 1k+ thanks though.Fronts- RTi8
Center- CSi5
Rears- FXiA4
Sub- Velodyne 12"
Onkyo TX-SR806
Ps3
Xbox 360
no apologies needed. that is a great AVR.Man Cave: 7.1
>Sub = MK Audio 10'
-PS3
-Directv
Rocco is right. But that's why I qualified above, dollar for dollar, pound for pound you can't beat the value of an 805 for 'sound'. The 806 has a bit better Video upconversion. But the 805 stomps it in sound because it's so much like the 875.
so the circuit topology in these two receivers from onkyo is different??
RT1
