Any plumbers on the forum?
ken brydson
ken brydson Posts: 9,017
edited May 2009 in The Clubhouse
Hey guys-
Seems to be a vast array of different skills here so I thought I'd throw this out...
I recently installed a new kitchen sink for a friend. No leaks, everything works great except when the dishwasher drains water comes out of the airgap and runs all over the counter. The air gap was new when I did the sink so I know it's not gummed up. The disposal looked kind of nasty inside, maybe that's it? All of the other hoses "seem" OK. Any other thoughts? TIA
Post edited by ken brydson on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited May 2009
    Not a plumper, but a jack of all skills. I would check the dishwasher drain hose at disposal for blockage. :)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • vlam
    vlam Posts: 282
    edited May 2009
    Yup.. that's the most probably cause. If your friend haven't use the dishwasher much, and uses the disposer daily, it will get blocked. You need to take out the drain hose from the dishwasher to disposer and clear out the blockage.
    In addition, make sure you do a loop with the drain hose above the connection to the garbage disposer. Don't want any dirty water going back into the dishwasher.
    No a plumber either.. just a DIY
    Main Gear
    Panasonic 50" Plasma, Polk LSi15 (Front), LSiC, LSi7 (Rear), Sherwood Newcastle AVP-9080, AM-9080 bi-amp to LSi15, AM-9080 bi-amp to LSiC and LSi7.
  • ohskigod
    ohskigod Posts: 6,505
    edited May 2009
    disneyjoe7 wrote: »
    Not a plumper..........
    boy, talk about lobbing a softball!!!rotflmao
    so many wise **** remarks came to mind, I got a head rush and almost passed out at my computer.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • lightman1
    lightman1 Posts: 10,797
    edited May 2009
    disneyjoe7 wrote: »
    You are kinda cute in a voluptuous way.
  • disneyjoe7
    edited May 2009
    I'm stupid at times, what can I say. :(
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Rivrrat
    Rivrrat Posts: 2,101
    edited May 2009
    disneyjoe7 wrote: »
    You should've taken credit for that one.:D
    My equipment sig felt inadequate and deleted itself.
  • nebborjk
    nebborjk Posts: 425
    edited May 2009
    Was the dishwasher previously connected to the disposal? If not check to see if the inlet for the dishwasher on the disposal is open. If a dishwasher was never connected to this disposal then the factory seal in the disposal may still be intact. You'll need a hammer and a screw driver to remove it.
    Proud SOPA Member since 2005!
  • ken brydson
    edited May 2009
    Thanks for all of the replies. Confirmed my suspicions. Gotta go back and check for blockage in the drain hose. The DW was in use before so I know the slug was knocked out already.
