Any plumbers on the forum?
ken brydson
Hey guys-
Seems to be a vast array of different skills here so I thought I'd throw this out...
I recently installed a new kitchen sink for a friend. No leaks, everything works great except when the dishwasher drains water comes out of the airgap and runs all over the counter. The air gap was new when I did the sink so I know it's not gummed up. The disposal looked kind of nasty inside, maybe that's it? All of the other hoses "seem" OK. Any other thoughts? TIA
Post edited by ken brydson on
Not a plumper, but a jack of all skills. I would check the dishwasher drain hose at disposal for blockage.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Yup.. that's the most probably cause. If your friend haven't use the dishwasher much, and uses the disposer daily, it will get blocked. You need to take out the drain hose from the dishwasher to disposer and clear out the blockage.
In addition, make sure you do a loop with the drain hose above the connection to the garbage disposer. Don't want any dirty water going back into the dishwasher.
No a plumber either.. just a DIYMain Gear
Panasonic 50" Plasma, Polk LSi15 (Front), LSiC, LSi7 (Rear), Sherwood Newcastle AVP-9080, AM-9080 bi-amp to LSi15, AM-9080 bi-amp to LSiC and LSi7. -
disneyjoe7 wrote: »Not a plumper..........
boy, talk about lobbing a softball!!!rotflmao
so many wise **** remarks came to mind, I got a head rush and almost passed out at my computer.Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
You are kinda cute in a voluptuous way.disneyjoe7 wrote: »Not a plumper, but a jack of all skills. I would check the dishwasher drain hose at disposal for blockage.
I'm stupid at times, what can I say.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote: »I'm stupid at times, what can I say.
You should've taken credit for that one.:DMy equipment sig felt inadequate and deleted itself. -
Was the dishwasher previously connected to the disposal? If not check to see if the inlet for the dishwasher on the disposal is open. If a dishwasher was never connected to this disposal then the factory seal in the disposal may still be intact. You'll need a hammer and a screw driver to remove it.Proud SOPA Member since 2005!
Thanks for all of the replies. Confirmed my suspicions. Gotta go back and check for blockage in the drain hose. The DW was in use before so I know the slug was knocked out already.
