MIT terminator question
unc2701
unc2701 Posts: 3,587
edited May 2009 in 2 Channel Audio
This may be a dumb question, but MIT has taken down the product info for the terminator line... Where does the terminator 6 stack up against the 5 or 4...or 3?
Is higher or lower better?
Thanks!
Backburner:Krell KAV-300i
Post edited by unc2701 on
  • daboyz
    daboyz Posts: 5,207
    edited May 2009
    Lower is better, I believe that's the case with all their cables but don't quote me.
  • strider
    strider Posts: 2,568
    edited May 2009
    daboyz wrote: »
    Agreed. I've got Terminator 3's and 4's, the 3's are noticeably thicker and have higher quality ends on them.
    Wristwatch--->Crisco
  • unc2701
    edited May 2009
    Yeah, I thought that was the case, but all the 2's and 3's that I saw had the old-school, ****-ugly boxes, so I started to second-guess myself.
    F1nut Posts: 52,298
    edited May 2009
    Those ****-ugly boxes (your words) are where the magic is.
    Personally, I love the looks of the boxes, says bad **** in my book.
  • unc2701
    edited May 2009
    I've got nothing against boxes... comparing within the MIT line, the 2's and 3's are the red-headed step children in the looks department; this made me question whether I had the pricing/ quality the right way around.
    t2.jpg 116.9K
    t3.JPG 19.7K
    t4.jpg 42.4K
    F1nut Posts: 52,298
    edited May 2009
    Ah, I see what you're going on about. The "white" cables are the very early versions. All the later Terminator series cables are gray.
