Media centers ,could be cd or more.
2
  • ben62670
    ben62670 Posts: 15,969
    edited May 2009
    It is much easier with the WMC remote;) I will have it running to my projector again. Also from what I have seen it is one of the easier programs to navigate with. I am all ears though.
    Ben
  • Sami
    Sami Posts: 4,634
    edited May 2009
    Also, what do you recommend as the OS for a file/print server?
    8.04 LTS: http://www.ubuntu.com/getubuntu/download-server
  • ben62670
    edited May 2009
    The problem is my PC is the main PC/server/HTPC I have a laptop that I will use remote desktop conection to browse my puter with.
    Ben
  • Ender
    Ender Posts: 603
    edited May 2009
    Why is that a problem? I would just install KM Player or VLC onto the laptop and play the files from the main PC with my laptop. You connect the projector to the main PC or laptop?
    SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
    Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
    GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
  • ben62670
    edited May 2009
    The main PC. It has a real nice graphics card, and a quad core proc. The main PC is what is hooked up to the DAC
    Ben
  • adam2434
    adam2434 Posts: 995
    edited May 2009
    My 2 cents:
    I don't personally see much value in video playback and don't have any desire to put movies on my computer. They would take up a huge amount of storage and we just don't watch movies over and over. In the future, streaming a movie from the internet in HD will be nice.
    For music, my experience is that streaming or playback from a computer does not have to be a compromise vs. standard CD playback, assuming it is done properly with the right ripping program/format (lossless or wav), right playback software/settings (to ensure bit-perfect), and good downstream equipment (good DAC).
    Regarding the back-up or safety of the files, I'm in a much safer position with my music on my computer vs. before. I still have the original CDs, have the music on my computer's HD, on an external back-up HD that is only connected when doing a back-up, and the files are also backed-up on DVDs which are stored outside of my house. After putting the time into ripping hundred's of CDs, I'm definitely taking extra precautions to protect the investment.
    Setting up a computer for music ripping/playback doesn't require any special hardware in the computer itself. I'm using our existing PC and didn't buy a new PC for this purpose. There is a lot of good free software for quality ripping and playback (EAC, Foobar, etc.). There are some ripping and playback software settings that can be optimized within the programs, so there is a learning curve.
    If the computer is near the audio equipment, you could use SPDIF or USB to your DAC or processor. Essentially the computer becomes a transport.
    If you want to stream music to multiple/distant locations over your home network, Squeezebox or Sonos systems are popular choices. They both have digital outs to connect to your DAC or processor. If you already have a computer with ample storage, an ethernet of Wi-Fi network, and a good DAC or processor, a Squeezebox Classic for around $280 is a relatively inexpensive way to stream your music in a high quality fashion.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • Ender
    Ender Posts: 603
    edited May 2009
    ben62670 wrote: »
    So when you say remote desktop connection, you mean your laptop takes control of your main PC? Is that only through WMC or does it take control of the whole computer?
  • ben62670
    edited May 2009
    Thanks Adam. That is where I am at till BR burners/players come down in price.
    Ender the RDC is a program built into windows that allows you to log on a remote machine just like you were sitting right there. I have the full processing power of my main PC from my laptop, or any other computer on the internet. The video sucks playbak, but it is very handy.
    Ben
  • Ender
    Ender Posts: 603
    edited May 2009
    And this forces you to only use WMC?
  • ben62670
    edited May 2009
    Not really. What I want is to be able to use just the MCE remote with Vista and Win7(next OS). The WMA is the most compatible format from what I hear that is lossless. I have over 60 Cd's ripped so far... I am not against using another program as a player when I am using the laptop as a controller.
    Ben
  • ben62670
    edited May 2009
    puter spazed
    Ben
  • ben62670
    edited May 2009
    puter spazed
    Ben
  • Ender
    Ender Posts: 603
    edited May 2009
    Hmm... So for music, you want to use the remote which requires WMC usage. For movies, since you can use your laptop as a remote, you can use whatever?
  • ben62670
    edited May 2009
    I want the option of the remote for when the projector is running, and when I get a BR player in the PC;)
    Ben
  • Ender
    Ender Posts: 603
    edited May 2009
    Lol. You need to get a new remote, basically. :D
  • ben62670
    edited May 2009
    Media center is way too easy when it works;) I have a tuner card for TV in all flavors, and FM. I don't know of anything that can be so easily controlled. I do not want a step learning curve. I am doing way to much other stuff;)
    Ben
    Ben
  • venomclan
    venomclan Posts: 2,467
    edited May 2009
    Anyone use an Apple TV as a server with a dedicated Dac? It looks like the best bang for the buck.
    Venom
  • jinjuku
    jinjuku Posts: 1,523
    edited May 2009
    Windows Media Player has an option to RIP and Copy protect music.
    Just clear the check mark.
    There are also some privacy settings to clear:
  • Sami
    Sami Posts: 4,634
    edited May 2009
    venomclan wrote: »
    Venom
    If you have an extra PC and some time, MythTV might be worth a look. It was originally a PC based PVR project but has evolved into a whole media centre through plugins.
    https://help.ubuntu.com/community/MythTV
    "Plugins from the MythTV community provide functionality for: DVDs, Personal Video Collection, Music, Weather, News, Gaming, Netflix and much, much more. "
  • okiepolkie
    okiepolkie Posts: 2,258
    edited May 2009
    The Apple TV would be decent, but a Mac Mini would be better, paired with a dac. I like the Mini because you can browse for music via remote, or via keyboard/mouse.
    Tschüss
    Zach
  • venomclan
    edited May 2009
    Sami wrote: »
    Thanks, but I do not want to incorporate a PC into the system due to noise, heat etc...
    okiepolkie wrote: »
    Same as above, but I know the MM would be smaller. From what I understand, The ATV has a remote for onscreen use browsing and an application on an Iphone/itouch to navigate that way. I also believe that the MM only has a USB out, my Benchmark DAC1 is the original with no USB. I would use the toslink with the ATV, loading it with lossless, fire and forget.
    Venom
  • okiepolkie
    edited May 2009
    venomclan wrote: »
    Venom
    One thing to keep in mind is that the Apple TV is HOT. I would say it puts off more heat than the Mac Mini, but I haven't had them side by side as a comparison.
    The new Mac Mini has an optical out from its headphone jack. You would just need the appropriate cable for it.
    Tschüss
    Zach
  • venomclan
    edited May 2009
    okiepolkie wrote: »
    I heard it runs hot. It is small so I don't know how it it really is, but compared to my old Krell's I'm sure it is ice :). Is it quiet though?. I do not think it has a fan, that is why it is hot.
    Would the Mac Mini headphone jack still be the same digital signal that a dedicated toslink would send? I did not know a headpohe jack could bypass the internal dac.
    V
  • adam2434
    adam2434 Posts: 995
    edited May 2009
    venomclan wrote: »
    V
    Yes, it's called a mini toslink.
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10229&cs_id=1022902&p_id=1556&seq=1&format=2
    You can also buy mini toslink adapters that allow you to use a standard toslink cable.
    That mini toslink and headphone combo jack is a neat feature on Apple products, including their computers and the Airport Express.
  • jinjuku
    edited May 2009
    venomclan wrote: »
    Venom
    Been running an HTPC for 3 years now. Noise floor is below ambient and it runs cooler than my receiver and external amps.
    I am running a fanless heatsink and Nexus PSU. Also have a 120mm fan modded to run on the 5volt rail to exhaust the case as an extra measure.
  • Ender
    Ender Posts: 603
    edited May 2009
    Yeah, if you build an HTPC right, you can just have RAM, power supply, motherboard, heatsink, some low speed case fans, and CPU. No noise and almost no heat. Nothing compared to my main gaming system anyways. In fact, I bet it makes about as much heat and noise as your receiver or amplifier.
  • venomclan
    edited May 2009
    Thanks for the input guys. The mini toslink solves the audio side, but on the video side, I do not see anything but the Mini video to VGA adapter and DVI. Can this thing be hooked up to a tv with composit or Component?
    V
  • adam2434
    adam2434 Posts: 995
    edited May 2009
    venomclan wrote: »
    V
    Hmmm, I don't think so, unless you use a VGA to component converter like this: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/audio-authority-convert-vga-signal-to-component-video-9a60/prod9A60.html
    Are you using a TV without VGA, DVI, or HDMI?
    Do you need a display for browsing music only, or also for video?
    If I were going to buy a computer for the primary purpose of a music server near my equipment, I'd probably look at one of the small Acer Aspire One notebooks (~$350) with a USB-capable DAC or in conjunction with a USB-SPDIF converter. You would not need another display for browsing music and have the benefit of having a notebook PC when not using it for music. Also, the Aspire One is very, very quiet. My daughter has one. The only downside is no disk drive - so you would need to get an external disk drive or rip and transfer from another computer (which would be easy to do if you already plan to back-up on an external HDD anyway).
  • venomclan
    edited May 2009
    I was plannig on using a small 5" monitor I have to navigate for a media server. I guess though with the prices of monitors, I can get an inexpensive computer lcd with the VGA. I use a larger lcd for video and gaming, that I plan to have off when doing 2 channel only. The ATV and MM call for some type of video navigating that a monitor will serve for.
    I was thinking of the Acer way. Monoprice does not have a us-toslink adapter. I cannot see Dac companies wanting this adapter aswhy would anyone buy the upgraded version of their dac if you can buy a cheap cable that will do the same thing.
    I like the Acer and I think it is uder $300 at BJ's. I believe it uses XP, which I prefer over Vista. Other than no disk drive, any downsides to the unit? I would like to use it for travel too and I think it has that advantage. I would just load the files onto an external hard drive and load onto the Acer.
    Venom
  • adam2434
    adam2434 Posts: 995
    edited May 2009
    Did you mean a USB-toslink adapter?
    If so, there is no simple adapter. You need electronics to make a USB to SPDIF conversions – something like a Trends UD-10.1, HagUSB, or Pop Pulse.
    Or, on the cheap for around $30, the Behringer UCA202 will convert USB to optical SPDIF. I don’t see why this wouldn’t be perfectly fine when used with a DAC with good jitter rejection.
    My daughter has the higher-end Aspire One, which was around $380 – bigger hd and 6 cell battery. For audio, the 6 cell battery is cool because you could essentially keep your transport off the power grid for several hours of listening.
    The keyboard is obviously smaller than a typical laptop’s, but is still very usable for a man with large hands.
    My daughter’s is so quiet that I thought they somehow made them without a fan. There is a fan, but it is very quiet. Plus, the processor they use is supposed to run very cool.
    They are basically a scaled-down full-featured laptop running XP, without a CD/DVD drive.
    If you fill up the internal hd, you could play files from an external hd.
    Another benefit is that you would not need another monitor for 2-ch, as you could use the Acer's screen. And when you want to view the Acer on your LCD, you just use a VGA cable.
