Qs about DSW-pro600 hooked to Elite SC-05
Hey People,
Anyone know why there's no separate sub plug-in or control on this receiver (it comes out the Center channel pre-)? Or have i just not found it yet? : o
I would love to play "pure-direct" stereo, sub assisted, but it turns the sub off in that mode (because it turns off the Center channel where the sub is plugged in - seems kinda dumb to me, but maybe I just don't know something...) Any ideas?
Also, there's just one plug dedicated to a sub on the receiver, but the sub itself has 2 rca ins.. how best to hook this puppy up ?
Thanks A Bunch In Advance!!
Jack
Post edited by jackflash on
    Toolfan66 Posts: 18,120
    edited May 2009
    jackflash wrote: »
    Hey People,
    Jack
    Go into your settings and set the sub to PLUS, as far as the sub just put the RCA in the left channel. It really don't matter there but i put mine into the left channel. There should be a sub connection on the back of your receiver.
    Hope this helps,
    Larry.
    edited May 2009
    I just looked at pictures of the back of the SC-05, your sub out is in your preout area same as my SC-07.
  • jackflash
    jackflash Posts: 2
    edited May 2009
    Hey Thanks so much for responding and looking into it!! I found the speaker set-up menu - and it has the "plus" feature in the manual (p.57) - but couldn't find the SW bit after scrolling through... thinking it might be an SC-07-only feature (which doesn't make sense - but what the hell!). That's what I get going all cheap and not gettin' yours or the sc-09 right!? : O
    I discovered the sub DOES play in the "Direct" mode w/o activating the center-channel...(just not the 'Pure Direct' mode...)
    edited May 2009
    jackflash wrote: »
    Correct!!
    The SC-05 has that feature to set your sub to PLUS, It took me a few to figure out the settings and features as well. The SC-05 is a great receiver don't under estimate your purchase just yet. read the manual and go through the features.
    Go to: System Setup
    Then to: Manual SP Setup
    Then to: Speaker Setup
    Then go down to SW (SubWoofer) go right or left with the arrows till you see it say PLUS. and your ready to go.
    Good Luck and enjoy, hope this helps.
    Larry.
