Need to replace my AT&T cell phone
fatchowmein
My old clamshell phone has a connection problem at the hinge. I don't care about music, camera, data, internet access, etc. Just need a phone that works with address book. Texting is optional (I get maybe 3 text a month). My 700 minute family plan (me + wife) is on month to month ($51 package that I somehow pay $80 a month for).
The AT&T store wants a 2 year renewel and either a $30 monthly texting package or $30 monthly data package just to replace a crippled phone. I told them they're nuts. Wife called AT&T and they told her the same thing.
Is there a simple way for me to just buy a replacement phone and slap my old sim card into it or do I need to switch carriers?
Post edited by fatchowmein on
Any GSM/SIM card based phone will work, fatchowmein, as long as the phone is unlocked (i.e. can take AT&T SIM card or TMobile SIM card, for that matter, and it should work). Or, buy a phone from a friend who had AT&T before)I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
check out this website. I've bought phones from them before and it was MUCH better then buying through some sleezy dealer or the actual company. I bought a t-mobile phone but I think they offer ATT too. www.mobilebee.com
I guess I was wrong, I can only find Tmobile phones. Sorry.
Try flea bay? You just need any GSM phone though stuff like buying ringtones or sending pictures might not work. -
Where are you located? I have a used nokia GSM phone if you are interested. Just pay shipping if you are not local.
vlam168@gmail.comMain Gear
Panasonic 50" Plasma, Polk LSi15 (Front), LSiC, LSi7 (Rear), Sherwood Newcastle AVP-9080, AM-9080 bi-amp to LSi15, AM-9080 bi-amp to LSiC and LSi7. -
Thanks for the advice and offers guys. Let me hit up the usual suspects first (coworkers, local friends, family).
If you really just want a phone, get any cheap prepaid phone for 20 bucks, and slap your SIM into it. A friend of mine did this when he broke his phone, worked like a champ. AT&T will NEVER tell you you can do this because they want to sell you an expensive phone.
Also, T-Mobile and AT&T both use GSM phones and will be interchangeable.If you will it, dude, it is no dream. -
craigslist usually has a bunch stuff.. My wifes phone broke the other day and we have been looking for a replacement
I agree, get a prepaid if you're tired of fees.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
bobman1235 wrote: »If you really just want a phone, get any cheap prepaid phone for 20 bucks, and slap your SIM into it. A friend of mine did this when he broke his phone, worked like a champ. AT&T will NEVER tell you you can do this because they want to sell you an expensive phone.
This is what I was going to recommend as well. One of the service reps actually told me to do this when my wife threw her phone in with the wash....Tschüss
Zach -
t-mobile and att phones are only interchangeable after being unlocked. Unlocked phones work with any/all SIM cards placed in them. I think the only carrier not using SIM card is verizon.
Airplay355 wrote: »Unlocked phones work with any/all SIM cards placed in them.
Yes but they might not be able to make calls!
NA standard frequency is 850/1900 I believe. If the gsm phone is a quad band phone, it will work anywhere in the world on a GSM network for voice. If it is only a dual band phone you need to make sure it runs on NA frequencies as the European frequencies are different.
Data is another story when talking about 3g. Almost all GSM phones that are 3g capable only have a radio for one specific 3g frequency. It would either be NA or Europe so if 3g is important to you, it needs to be considered when shopping for an unlocked phone. If 3g isn't important, any phone that works with your carrier for voice will also work with EDGE (or 2g) as it operates on the same frequency as voice.
As stated, any phone from AT&T will continue to work on that provider unlocked or not.
I'm in the cell phone upgrade zone myself and can't decide between the HTC Touch HD and the HTC s743. (I like my gadgets!) -
He's actually recommending to get a prepaid phone to use with his existing AT&T account. $20 for a basic Nokia phone from AT&T prepaid works with AT&T account, I don't know for sure if T-Mobile works or not so I would stick with the AT&T prepaids.I agree, get a prepaid if you're tired of fees.
