Partition Recovery
Pauly
Pauly Posts: 4,519
edited May 2009 in The Clubhouse
Need help on how to recover a partition i deleted. Basically i have 2 drives. I was re-installing XP because 7 was giving me issues. In the process i accidently deleted the partition on my backup drive. i caught it a nano second after i hit delete. Now i didnt format the drive so i know the data has to be there. Google isnt giving me a whole lot other than Buy Me Software. If i have to i will buy some software but there has to be a free way.
Any help is appreciated.
Pauly
Life without music would
Post edited by Pauly on
  • ben62670
    ben62670 Posts: 15,969
    edited May 2009
    Do you have an FTP I can upload a program to?
    Ben
  • Pauly
    Pauly Posts: 4,519
    edited May 2009
    I had FileZilla on that drive :)
    I built a new computer so im still getting everything up and running. So at this moment. No i dont. What program is it?
  • ben62670
    edited May 2009
    a very expensive one. I am going tobe bouncing here for a few, but I can get it to you later today.
    Ben
    Ben
  • Pauly
    Pauly Posts: 4,519
    edited May 2009
    ben62670 wrote: »
    Ben
    Ok well im at work at the moment. If i cant find another solution tonight i'll hit you up.
    Pauly
  • Polk user
    Polk user Posts: 311
    edited May 2009
    You can download this for free and install it on the drive that is NOT missing the partition.
    http://www.runtime.org/data-recovery-products.htm
    If you see the partition you can then purchase the product to recover it.
  • bruss
    bruss Posts: 1,039
    edited May 2009
    what about disk managment in windows?
  • Pauly
    Pauly Posts: 4,519
    edited May 2009
    bruss wrote: »
    Never used it. Its on my 2nd/backup drive. At this point im not gonna do anything with it but try and recover the partition. I'll look into that.
  • Pauly
    Pauly Posts: 4,519
    edited May 2009
    Lasareath wrote: »
    Ben, Pauly, I have an FTP site you can use to upload the program to.
    I'll create a new user now and send you the info
    Sal
    Sounds good.
    Thanks,
    Pauly
  • ben62670
    edited May 2009
    OK I am sending it soon as i find it;)
    Ben
  • Pauly
    Pauly Posts: 4,519
    edited May 2009
    Cool ive got few options im gonna try later. Just skeptical about using freeware. Might be a last straw type thing. I mean its only 2000+ pics and some 10,000 songs :rolleyes::rolleyes:
    Pauly
  • greg2350
    greg2350 Posts: 544
    edited May 2009
    Try this http://www.ultimatebootcd.com/
    its free and I have used it for various problems with success
    has to many tools to list see the site
    TV: Philips 42" LCD 1080p
    Front Speakers: Polk Audio RT800i
    Center Speaker: Polk Audio CS1
    Surround Speakers: Polk Audio R50's powered of Denon AVR
    Subwoofer: Polk Audio DSW pro500
    AVR: Denon 3801
    DVD Player: Denon DVM 745 upscale 1080p
    Sat: Directtv HD 10
    Front Speakers Amp: Rotel RB 890
    Center Speaker amp: Rotel 970 BX
