Polk Audio Monitor 10 (1987) problems.
tshade530
tshade530 Posts: 13
edited May 2009 in Vintage Speakers
Recently, one of my Polk Monitor 10's (Dated Late 1987) stopped working for the most part. The tweeter still works fine, but the drivers and woofer make no sound at all. I checked all connections to the receiver and what-not, but wanted advice before i go taking it apart (i'm fairly new to speakers). However, all the other speakers, including my other monitor 10 still work perfectly. Any ideas what may cause this?
Thanks for any help!:D
Home Theater System
TV: Samsung LN52A850
DVD: Toshiba HD-A30 (:mad:)
Satellite: Dish Network VIP722 HD-DVR
CD-Player: Pioneer 25-disc changer
Gaming Systems: Nintendo Wii, Playstation 2, Xbox.
Receiver: Sony STR-DG1000 Receiver
2 Polk Audio Monitor 10's (Dated 1987)
1 Polk Audio Monitor CS100
2 Polk Audio Monitor Satellites (not sure of model)
2 Bose Bookshelf Speakers (Model 301)
Bose Acoustimass 16 Cubes and Subwoofer
:D
Post edited by tshade530 on
  • Ender
    Ender Posts: 603
    edited May 2009
    Have you ever replaced the caps on the crossover?
    SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
    Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
    GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
  • tshade530
    tshade530 Posts: 13
    edited May 2009
    Ender wrote: »
    Hi there,
    Sorry for being a complete noob, but i'm not sure what you mean exactly...could you clarify what the caps on the crossover are for me?
    Thanks!
    Home Theater System
    :D
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2009
    Don't worry about caps.
    Move the loudspeaker to the other channel, and see if the problem follows the speaker.
  • tshade530
    tshade530 Posts: 13
    edited May 2009
    dorokusai wrote: »
    If you meant moving the entire speaker to the left front channel (its currently right front), I tried that with no result.
    Home Theater System
    :D
  • dorokusai
    edited May 2009
    Did you get the same result? No bass, only the tweeter was working? One speaker works just fine correct?
  • tshade530
    tshade530 Posts: 13
    edited May 2009
    dorokusai wrote: »
    Yes, when i moved it over, the tweeter was still the only speaker that made any noise at all. The Mid-Range Drivers and Woofer still make no sound at all. And yes, my other monitor 10 works fine on either channel.
    Home Theater System
    :D
  • dorokusai
    edited May 2009
    OK, use a philips screwdriver and remove the mid-bass drivers from the non-working speaker. Ensure the leads are connected to the back....two of them for each driver. I would swap both to the "working speaker" and see what the result is.
  • tshade530
    tshade530 Posts: 13
    edited May 2009
    dorokusai wrote: »
    Yes, there are two wires running to each mid-range driver. I will swap them here in a bit and post back with results.
    Thanks for the help so far!
    Home Theater System
    :D
  • tshade530
    tshade530 Posts: 13
    edited May 2009
    tshade530 wrote: »
    However, there are no wires to the subwoofer...should there be any wires to it?
    Home Theater System
    :D
  • dorokusai
    edited May 2009
    That's a passive radiator not a subwoofer so it won't have any wires connected to it.
  • tshade530
    tshade530 Posts: 13
    edited May 2009
    dorokusai wrote: »
    Just an update, while i was trying to figure out how to disconnect the speakers (they are soldered to the speaker), i realized that when i put my ear right up to the mid-range drivers, they are making sound, its just such little sound that it cant be heard from more than 3in away...
    Home Theater System
    :D
  • HB27
    HB27 Posts: 1,518
    edited May 2009
    GENTLY push in on the mid drivers and make sure they move freely and have no scraping or scratchy feeling. Do not touch the center dust cap as it will collapse it.
    If the mids in the problem speaker are stiff and little or no movement that's most likely the problem. You can compare travel of the mids from the good speaker vs the problem speaker.
    You'll eventually run the problem down. Don't be afraid to ask. That's what the forum is for. Lots of good, helpful, knowledgeable people here.
    Good luck and "keep us in the loop"
    Harry
  • tshade530
    tshade530 Posts: 13
    edited May 2009
    HB27 wrote: »
    Harry
    :D...Harry, I think you may have solved my problem. When i touched the mids, i realized that they wont move AT ALL...im not sure why i didnt try this before...how do i fix that, or can i?
    Thanks!
    As a side note: The good speaker has quite a bit of travel in the mids, where as the bad speaker literally wont budge at all...
    Home Theater System
    :D
  • bluecomet
    bluecomet Posts: 1,118
    edited May 2009
    It sounds like a frozen speaker. Did you jar or bump this speaker. If it is frozen you will have to replace the mids. Maybe Polk has replacements.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
  • tshade530
    tshade530 Posts: 13
    edited May 2009
    bluecomet wrote: »
    Nope, i just remember one day when i was watching a movie (it wasn't turned loud, maybe about 1/2 volume) and i heard it make a strange sound, when i paused the movie to go look at it, it was completely silent aside from the tweeter...i'll look into replacement mids.
    Side note: Do you guys think replacement mids are worth it for a 22 year old monitor 10?, or should i just remove them both from my system and replace them with something else?
    Home Theater System
    :D
  • bluecomet
    edited May 2009
    For the price of new mid's for the Monitor 10's, you will not find a better new speaker. The mid's should run you about a hundred bucks. If your monitor's came with the peerless tweeters I would not part with them.
  • tshade530
    tshade530 Posts: 13
    edited May 2009
    bluecomet wrote: »
    Sorry for the poor quality image, it was taken with a camera phone
    Which tweeters are these? These are the tweeters in both of my Monitors.
    Home Theater System
    :D
  • fbm211
    fbm211 Posts: 1,488
    edited May 2009
    You should replace all the mids with new ones or try to find some used ones of the same model.New mids in one will result in one speaker sounding off.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • tshade530
    tshade530 Posts: 13
    edited May 2009
    fbm211 wrote: »
    Hmm...so you're saying i should replace all 4 mids instead of just the 2 in the bad speaker? The inside of my mids on the bad speaker say that they are MW 6503 Drivers. Would i look for 4 6503's or are there better ones for this speaker?
    Thanks for all your help guys, I really appreciate it!
    Home Theater System
    :D
  • fbm211
    fbm211 Posts: 1,488
    edited May 2009
    Look for the 6503s Thats the right one for that model.Try ebay for 2 used ones.Or call polk to get 4 new ones and mention your a club polk member and you will get a 20% dscount plus free shipping. About 400.00 for 4 of them.
  • tshade530
    tshade530 Posts: 13
    edited May 2009
    fbm211 wrote: »
    Does this seem like a good deal?
    http://cgi.ebay.com/Polk-Audio-Pair-MW-6503-Bass-Midrange-6-5-monitor-10_W0QQitemZ320367426737QQihZ011QQcategoryZ50597QQssPageNameZWD1VQQrdZ1QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
    Home Theater System
    :D
  • fbm211
    fbm211 Posts: 1,488
    edited May 2009
    A little high for used ones.Those would have to be packed carefully and you should ask seller for a return warranty just in case.
  • tshade530
    tshade530 Posts: 13
    edited May 2009
    fbm211 wrote: »
    Yeah, i was thinking that as well...but unfortunately thats the only MW 6503's i can find on eBay right now. Oh well, i guess ill just remove the monitors for now and replace it with another set of speakers i have until i find a better deal. Thanks guys for all the help!:D
    Home Theater System
    :D
  • fbm211
    fbm211 Posts: 1,488
    edited May 2009
    Maybe another member might chime in who has a pair of 6503s to sell.
  • bluecomet
    edited May 2009
    If you get those on ebay, you won't have to change the other speakers mids. I would consider those. They are what you are looking for. I believe the tweeters you have are the SL2000's. If I were you I would buy the new replacement RDO 194 tweeters for the monitors and buy the mid's on ebay and they should sound better than new. It should run about two hundred for everything.
  • HB27
    HB27 Posts: 1,518
    edited May 2009
    tshade530 wrote: »
    You don't have to do everything at one time and it's amazing how fresh drivers on one side of the room will change everything. It's pretty cool getting the knowledge of what happens when you do things a little different. Also you might be surprised how much you can like the sound quality with a little different sound until you can replace everything.
    As far as the value of bringing your Monitors back to life?
    Just look around at prices of speakers that aren't nearly as good as what you have now. A couple hundred bucks or more on a complete rebuild is cheap for great speakers.
    You can easily spend 5 times as much to replace your speakers and get much less than you would to rebuild what you have now.
    Best of luck to you.
    Harry
  • HB27
    HB27 Posts: 1,518
    edited May 2009
    tshade530 wrote: »
    Thanks!
    You might want to use JB Weld to secure the magnet structures to the basket on your good speakers. Your old monitors MWs fell apart. The glue dries up and loses adhesion with time allowing the magnets to slip.
    You can secure your good MWs now and not worry about them again.
    Harry
  • dorokusai
    edited May 2009
    Just stagger the new drivers. There's no need to buy 4 at one time. If using JB Weld makes you feel better go for it but I wouldn't bother.
  • polkmeister
    polkmeister Posts: 26
    edited May 2009
    dorokusai wrote: »
    Totally agree. I have a pair of vintage model 10's (circa '79) and THREE pairs of vintage 7's. (also an LSI based "main system".)
    On the old polks I've had to replace only two drivers amongst all of them over the years. For the life of me, I could not discern a difference between those repaired, from those still in original condition. BTW, it's a little surprising that BOTH mids went out on the one unit simultaneously... unless the speaker took a fall, etc.
    In short, I would just replace the frozen drivers in the one unit, or stagger them between the "good" unit and the one needing repair ... as suggested by dorokusai above. Good luck!
    ______________________________
    F: 1pr LSi15's ebony
    C: LSiC
    Surr: 1pr LSi15's ebony
    Surr,R: 1pr LSi9's ebony
    Sub: Epik Dynasty
    Outside: 4x Atrium 65SDI
    Legacy Remotes (pristine): 1pr Polk 10's, 3pr Polk 7's
    AVR: Onkyo TX-SR806
    PA's: 6x NAD2400
    Video: Sony KDL-52XBR6
