Opinion on BAT VK-P3 phono
haimoc
Does anyone have experience with this BAT phono?
Post edited by haimoc on
I had one in a BAT VK3i pre amp years ago. It was very good for an internal card. It was quiet, and had two gain stages for MM/MC cartridges by sliding a switch on the card. I can't remember if you could change the cartridge loading by inserting resistors into connectors on the card. I may be confusing that feature with another phono pre amp. You could check with BAT on that. They are very helpful.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Thanks for the info. I don't know there is a MC/MM switch on the card..
