Opinion on BAT VK-P3 phono
haimoc
haimoc Posts: 1,031
edited May 2009 in 2 Channel Audio
Does anyone have experience with this BAT phono?
Post edited by haimoc on
    SCompRacer Posts: 9,088
    edited April 2009
    I had one in a BAT VK3i pre amp years ago. It was very good for an internal card. It was quiet, and had two gain stages for MM/MC cartridges by sliding a switch on the card. I can't remember if you could change the cartridge loading by inserting resistors into connectors on the card. I may be confusing that feature with another phono pre amp. You could check with BAT on that. They are very helpful.
  • haimoc
    haimoc Posts: 1,031
    edited May 2009
    Thanks for the info. I don't know there is a MC/MM switch on the card.. :)
