Sunfire vs ICE
nooshinjohn
I do not want to start a flame war with this post. I am comparing my current rig to a Pioneer Elite...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEBIDX:IT&item=370195502647
I feel the weakest component in my current setup is my Yamaha and am looking to replace it with something better when I came across this. My question comes down more to the power section of the Pioneer vs. my Sunfire. I concede already that the Pioneer is a far superior piece of gear as a pre/pro is concerned. Am I better off just looking for a better pre/pro or getting the Pioneer and be done with it. I run my setup 70/30 between music/movies.
thanks guys
thanks guys
Post edited by nooshinjohn on
The Pioneer Ice is COLD and the Sun-FIRE is HOT. Hope this helps.:)
LMAO.... I thought the same thing but being cool can be hot too. Just ask that Hilton chick. Any opinions on the amps?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Buy a solid pre and buy a solid amp. Be done with it.
Ben -
I would talk to Sherardp as he has the Ice and Fire setup.
John, you don't detail why you "feel" that your 861 is a weak point, since it would appear to be excellent as a pre-pro. If you mean that some processing feature that you want is missing, then consider a receiver which includes it. For example, the Denon and Onkyo receivers which include Audyssey auto-calibration and room equalization.
As far as the amplification itself, there doesn't appear to be any good reason why your present Sunfire wouldn't be at least as capable as the Pioneer which you mention. There's no special magic in either the "ICE" amplification technology or any other. As long as there's flat 20Hz-20KHz frequency response with inaudibly low noise and distortion(which is typical these days), nothing more is possible from an amplifier. -
All amps that spec 20-20khz with the same distortion specs do not sound the same.
Ben -
I think your weakest link would be that you have a surround system with four different series of speakers, and no sub. You'd gain a lot more with just a sub, than from changing your pre or amp.
Besides, the Sunfire seems to be a great amp, far outperforming the Pioneer. -
I run my SC07 as a pre, I have it paired with Sunfire/D-Sonic Amps. If you want the in your face processing the elite has to offer, go for the SC-05. and use it as pre/proShoot the jumper.....................BALLIN.............!!!!!
I agree. You already have a nice amp, why not just add a nice preamp like using the SC-05 or 07.
Nothing wrong with the SC-09 , I actually am debating if I should buy it myself.
DanDan
That's about as poor of information as you can give..........laughable as well too!!
Here's some reading for you to explain a few things that makes a great amplifier.
http://passlabs.com/pdf/articles/leaving_class_a.pdf
http://passlabs.com/pdf/articles/distortion_and_feedback.pdf
There's a WHOLE lot more to an amp than flat response and low noise.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
