polkmm12
Systems
do u think that the polk mm12 would fit underneath a '03gmc kig cab truck in the back????
thanx
jake
thanx
jake
Testing
Testing
Testing
Testing
Testing
i have a 96 gmc extended cab and i have two mm12s under the back seat
i had to take the jack and stuff out and put it in the tool box though...but with the newer models i dont believe they have a huge box with a jack and stuff in it
i got the box at a local shop for $120
-Cody -
ya u're better off to go with a vehicle specific box... trying to jam that momo box under the seat is a waste of your time and money... by the time u got it to fit you'd have to downfire it and screw feet onto the box... thats even if u could get it to fit.
best off getting a front firing-under the seat- standard box. while its not as flashy, it'll function better, and probably cost the same...
figure a momo raw driver is like 200 --- momo with plexi box is like 350? ... i'm sure u could find a box for a single sub to vehicle specific fit under your back seat for less than 150 bucks.The Artist formerly known as PoweredByDodge
