polkmm12
Systems
Systems Posts: 14,873
edited July 2003 in Car Subwoofer Talk
do u think that the polk mm12 would fit underneath a '03gmc kig cab truck in the back????
thanx
jake
Testing
Testing
Testing
  • sntnsupermen131
    sntnsupermen131 Posts: 1,831
    edited July 2003
    i have a 96 gmc extended cab and i have two mm12s under the back seat
    i had to take the jack and stuff out and put it in the tool box though...but with the newer models i dont believe they have a huge box with a jack and stuff in it
    i got the box at a local shop for $120
    -Cody
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited July 2003
    ya u're better off to go with a vehicle specific box... trying to jam that momo box under the seat is a waste of your time and money... by the time u got it to fit you'd have to downfire it and screw feet onto the box... thats even if u could get it to fit.
    best off getting a front firing-under the seat- standard box. while its not as flashy, it'll function better, and probably cost the same...
    figure a momo raw driver is like 200 --- momo with plexi box is like 350? ... i'm sure u could find a box for a single sub to vehicle specific fit under your back seat for less than 150 bucks.
    The Artist formerly known as PoweredByDodge
