An excess of bass
quadzilla
quadzilla Posts: 1,543
Probably not what most people complain about, but I hooked up a pair of M&K V-125s last night to replace the PSW 450s I've been running. The reason for the change is that the PSW 450s, while very nice subs, started to roll off a bit earlier that I wanted, and have a -3db lower limit of 35Hz. The M&K -3db is 20Hz for comparison (I'm thinking this will take movies to a whole new level). Now, however, I'm trying to get them integrated into the rest of the system, and I notice a bump in the lower frequencies. This is especially noticeable on something like Chili Pepper's albums. Before, Flea's bass line just lacked a bit of low-end punch, but was otherwise very smooth. Now, the low end actually seems almost boomy, despite the sealed enclosure. There's a definite increase in volume in the lower registers, even after running the calibration on the AVR several times. I have all speakers set small, and the crossover is at 80Hz. Anyone have any tips on getting the subs smoothly integrated again?
Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Post edited by quadzilla on
  • Ern Dog
    Ern Dog Posts: 2,237
    edited April 2009
    I've had this happen before and what helped was to move my rig to the other side of the room which greatly reduced the boom. Room placement of subs is key. Another idea I haven't tried yet is adding some bass traps to help reduce the peeks and valleys in the lower frequencies. A third idea is to get a Velodyne sms-1 bass management system. These things are awesome and I love mine. It has helped to integrate my sub seemlessly with my speakers. Using the eq will reduce the boom and reveal the frequencies that all the boom is masking. You can get them used for $300.
  • quadzilla
    edited April 2009
    Hi Ern,
    So the Velodyne unit works with any subs? Cool, I didn't know that. I'd assumed it was part of a Velodyne set up. I'll definitely have to keep my eyes open for one.
    Your point about placement is dead on. I did finally get this sounding very nice by moving the subs from the opposite corners where I had the PSW 450s to putting the V-125s along the middle of the side walls. The final step was to face them towards the front of the room, rather than facing them into the room. Bass is now very deep, and fairly tight with little to no boominess. I think I can get it tighter and level things out a bit more, but the difference between where it was Saturday when I first hooked everything up and where it is now is night and day.
    I still want a pair of Micropro 4000s though.
    Arm: Rega 300
  • thsmith
    thsmith Posts: 6,082
    edited April 2009
    Quad, for now make sure your subs are balanced output to mains by using AVR test tone and RadioShack SPL meter.
    Acoustic panals will help alot.
    Another option to SMS-1 is to learn Room EQ Wizard (REW, free at hometheatershack.com) and use a $99 BFD 1124P to tame the peaks.
    You will need a PC with sound card that has mic in.
    You can't boast dips or shouldnt with SMS-1 or BFD.
    REW and SMS-1 will help with placement to minimize dips but you need filters to cut the peaks.
  • quadzilla
    edited April 2009
    Hi th,
    I've got a feeler out to a guy here locally that makes panels. Hopefully, I'll hear something back from him. I'll look into the rest of what you mentioned.
    How good does the mic and sound card need to be? I've got a laptop with an integrated SoundMax chipset and have a couple of cheap PC mics laying around. I might still have a couple of Shures floating around somewhere if that would improve the accuracy. Or I have a PC with an Audigy card. Of if there's something else that would work better, I can go grab that. Or maybe it doesn't make that much difference and I'm over-thinking this whole thing?
    Thanks for the response.
    Arm: Rega 300
  • thsmith
    edited April 2009
    quadzilla wrote: »
    Hi th,
    Since you live in Richardson, I work in Richardson and live in Plano we should meet.
    A friend of mine made bass traps and my wife makes the covers for the Owens Corning 705s that is pictured in my show case. The 705s can be bought locally at SPI for about $12 a piece. I do not use Bass traps but they would help me. My room is just not suited for them but the OC 705 panals help.
    I use the Turtle Beach SRM SC. Since we are local I would be glad to give a REW Demo.
    I know longer need the BFD since my SVS sub had 1 programable filter and luckly that is all I need but without REW I would not have been able to figure out how to set it.
  • thsmith
    edited April 2009
    Here is a picture of my friends Bass traps. Behind the covers he cut and stacked triangle OC 705s in a frame. They work very well.
  • quadzilla
    edited April 2009
    Hey, yeah, I'd love to see your set up. And you're more than welcome to see mine.
    Arm: Rega 300
  • Dagoods
    Dagoods Posts: 32
    edited April 2009
    I could not think of it this morning when you asked me but Here's a link to where I got the idea from to make the one's posted. It shows them with the covers off and how they made the frames. I made mine just from looking at the pictures.
    http://www.hometheatershack.com/forums/home-audio-acoustics/7758-corner-traps-finally-finished.html
  • thsmith
    edited April 2009
    Dagoods wrote: »
    And a nice job it did taming those Outlaws:cool:
