MM2084 dual sealed box
zyssai
Hi!
I want to make a box for 2 subwoofers MM2084 8"
I think dual sealed box is the better choice, isn't it?
Every sub must be in a seperate volume or I can mount the 2 subs in the same volume?
Thanks and sorry for my english, I'm french
Post edited by zyssai on
so for seperate boxes you would divide by 2? also what is meant by damped? u mean like poly-fil or dynamat?Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
thanks for your answers
but finally, I will install only one subwoofer
because of my amp, I have only 1x230rms 4ohms, and I don't have enough money to replace it
so another question, the recommanded volume for a sealed enclosure for one mm2084 is 9.9l (0.35cu ft3), but I must remove the subwoofer volume or not?
and if I want to mount it inversed? the volume will be reduced but how many?
Another question what crossover frequency do you recommand for this subwoofer? I think 80Hz @12db?
Many thanks!!! (and sorry for my english ) -
unless their dvc, then u could do 2.Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
