anyone ever heard of this model of harmon kardon?
nduitch
nduitch Posts: 316
edited April 2009 in Electronics
http://youngstown.craigslist.org/ele/1114159469.html
I've negotiated the price down to a firm 10 bucks, does anyone know anything about harmon kardon stuff of this vintage or this particular model? Is it worth 10 Bucks?
Thanks,
Nate
Post edited by nduitch on
  • oifvet0608
    oifvet0608 Posts: 148
    edited April 2009
    Wow...that thing IS old, definitely worth $10 bucks, good luck finding parts to fix it though.
    Receiver: Marantz SR7002
    Fronts: Canton Chrono 509 DC
    Center: Canton Chrono 505 CM
    Surrounds: Canton Chrono 502 SP
    Sub: SVS PC12-NSD
    TV: 40" 1080i JVC Multisystem LCD(upgrading to 50" Samsung LED)
    Blu-Ray: PS3
    DVD: Pioneer DV-420V (HDMI)(for PAL DVD's)
    Audio/Music: MacBook Pro hooked up thru HDMI
    Gaming: PS3 (oifvet0608) XBOX 360 (JAYtheVET)
    Cables: Inakoustik Reference
  • nduitch
    nduitch Posts: 316
    edited April 2009
    Someone correct me if i am wrong, if it is a problem with the caps then it wouldn't be a huge deal to replace them here or there.
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited April 2009
    If you can fix it yourself, it's probably worth $10. If you plan on paying for repairs, I wouldn't bother.
  • nduitch
    nduitch Posts: 316
    edited April 2009
    Here it is, I bought it a few hours ago. And jut like he said there is a constant scratchy like sound constantly, any ideas? He also said that the scratchy-ness gets better after about 2 hours, but still remains.
  • oifvet0608
    edited April 2009
    Check all connections, look for burns on the motherboard. You might want to contact HK and see if they have a set of schematics that you can download or they can send you. With a piece of equipment that old you should not have that hard of a time fixing it if you have a basic electrical knowledge.
    Sub: SVS PC12-NSD
    Blu-Ray: PS3
  • nduitch
    nduitch Posts: 316
    edited April 2009
    No burns on board, looks pretty clean. Im on hold with HK CS now, the thing is making a beeping noise, It seems to be picking up interference from my iphone as it gets louder the closer I hold it to the unit. Discontinued in 1975! it is 10 years older than me! It has been playing for about 30 min now and the scratchy-ness has subsided, still doesnt sound that great.
  • nduitch
    nduitch Posts: 316
    edited April 2009
    The caps say 6500 and 2200+2200 mfd's what does this equate to in uf's?
