anyone ever heard of this model of harmon kardon?
nduitch
http://youngstown.craigslist.org/ele/1114159469.html
I've negotiated the price down to a firm 10 bucks, does anyone know anything about harmon kardon stuff of this vintage or this particular model? Is it worth 10 Bucks?
Thanks,
Nate
Thanks,
Nate
Post edited by nduitch on
Wow...that thing IS old, definitely worth $10 bucks, good luck finding parts to fix it though.Receiver: Marantz SR7002
Fronts: Canton Chrono 509 DC
Center: Canton Chrono 505 CM
Surrounds: Canton Chrono 502 SP
Sub: SVS PC12-NSD
TV: 40" 1080i JVC Multisystem LCD(upgrading to 50" Samsung LED)
Blu-Ray: PS3
DVD: Pioneer DV-420V (HDMI)(for PAL DVD's)
Audio/Music: MacBook Pro hooked up thru HDMI
Gaming: PS3 (oifvet0608) XBOX 360 (JAYtheVET)
Cables: Inakoustik Reference -
Someone correct me if i am wrong, if it is a problem with the caps then it wouldn't be a huge deal to replace them here or there.
If you can fix it yourself, it's probably worth $10. If you plan on paying for repairs, I wouldn't bother.
Here it is, I bought it a few hours ago. And jut like he said there is a constant scratchy like sound constantly, any ideas? He also said that the scratchy-ness gets better after about 2 hours, but still remains.
Check all connections, look for burns on the motherboard. You might want to contact HK and see if they have a set of schematics that you can download or they can send you. With a piece of equipment that old you should not have that hard of a time fixing it if you have a basic electrical knowledge.Receiver: Marantz SR7002
Sub: SVS PC12-NSD
Blu-Ray: PS3
No burns on board, looks pretty clean. Im on hold with HK CS now, the thing is making a beeping noise, It seems to be picking up interference from my iphone as it gets louder the closer I hold it to the unit. Discontinued in 1975! it is 10 years older than me! It has been playing for about 30 min now and the scratchy-ness has subsided, still doesnt sound that great.
The caps say 6500 and 2200+2200 mfd's what does this equate to in uf's?
