Who makes a good XLR cable?
Nicknice
Hello everyone, I was just wondering who makes a good XLR cable to connect a processor to an amp?
Thanks in advance for your help
Post edited by Nicknice on
Welcome Nick!
I really like Signal Cables XLR's. Nicely made, relatively inexpensive.
http://signalcable.com/analogtwoxlr.html
I think Frank still gives discounts to Club Polk members.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Canare has pre-made XLR using quad star. Get them from any online, pro-audio type store.
Thanks for quick responses. Have actually looked at both of those sites. I'm sure both of them are great, but which one is better? I'm kind of leaning towards the Signal Cables, I prefer the look.
Did you look at Canare?
http://www.markertek.com/Product.asp?cat=CABLESCONN&subcat=AUDIOCAB&prodClass=AXLRXLR&search=0&off=0&baseItem=SC100XXJ
You didn't say what you would be using them for. Canare makes the cable in these ... if you look you will see BJC is using Canare in some of there stuff.
Plus these reasonable priced XLR's from Canare are using Neutrik connectors, pretty much considered a top quality connector manufacturer.
W -
Just checked them out Wizzy, they look pretty solid. Thanks
Either will work well, flip a coin. Blue jeans is good, as are the others mentioned. I like Franks work. I ran Signals' digital XLR between my transport and DAC for many years, nice cable.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Actually those cables aren't manuf by Canare, just using Canare and Neutrik. Canare also produces/distributes their own XLR/XLR cables.
The cable in those is 24 gauge, I believe the signals use 22. -
Me..Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
+1 for Ben. I have not heard or used them myself...yet, but have heard great things about them.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Also Ben contributes a lot to the forums, and has helped quite a few people here ... so that is a plus, indeed.
I really like Cardas cables and they terminate any of their cables in XLR or unbalanced for the same price.
Everyone thanks for all of your help. I'm not going to need these until I buy a new surround processor, which will be a few months. But I figured I would start looking now to see if I could find any deals.
WireWorld
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
